Hi all ![]()
As I also told Adrian in a PM; I’m planning on releasing v1.0 some day soon now. But as I also know that a lot of people will be annoyed with me breaking stuff, so it holds me somewhat back.
Hi all ![]()
I love your dashboard and i’m aware it is still a test version. If the next version break some functionality i’ll fixed it. Don’t hestitate to publish your newest version.
One dashboard is: “source”: “localstorage”, “title”: “Theo PC”, and have to move to “source”: “homey”, .
So if something breaks is that not a problem.
Now I hoping that a soort of copy/paste is possible to make it easier.
I tried the latest development version, and still a bit confused now.
in the “old” (=current) version I have 2 dashbaords (i.e. dashboard “devices” in Homey Pro), and I can see both
in the “new” (=development) version I only see one of those … in more recent versions it somehow has been converted … in the latest most recent attempt it says, it has been converted (and that I could save it if I like), but the dashboard then is empty …
somehow I would like to keep the old dashboard version until I migrated everything manually and know that it 100% works, before I suspend the old version dashboard.
will this be doable (maybe with a separate homey app)?
Hi ![]()
I don’t think it will be doable having two separate apps for both the old and new versions. I think Athom might also complain if I do something like that ![]()
As long as you haven’t tried saving the dashboards, no changes has actually been applied to your old dashboards. One of the changes I’ve implemented, but not released in the installable Homey App yet, is that a “Dashboard device” in Homey, will now be a “Store device”. So users don’t have to create individual devices for every dashboard they want. But the main reason is the powerful template feature I’ve implemented. A template can look like a simple but customized widget, or it might be an entire dashboard itself. I’m looking forward to seeing where this ends up going in the future ![]()
Back to what you’re experiencing; You only see one of your dashboards in the development version? And viewing that dashboard is completely empty?
My goal before releasing the new version, is that most users should be able to see and use their existing dashboards. Though, because of technical difficulties, they might look somewhat different.
menu does not even open … it shows the info box in the lower right corner, the menu icon in the upper left (but nothing happens when clicking on it).
tried the same on test environment: here it works, but no version info shown
For me every thing in the new version will be totally new.
When I try in the pas to look in to it I get that moving lemniscate (?) for minutes.
Then I close the side and looked never after.
Hmm… ![]()
Sanity check; you’ve tried refreshing the page a couple of times, just to make sure the latest version is loaded by your browser?
The error message you sent gives me some to work with, but also confuses me, as there is no usage of .find() method in StoreDialog ![]()
used several times F5, Ctrl-F5 etc. which should definitely reload everything.
any other hints what I could try
wait … now I get it:
but as soon as I open my Main Dashboard, it no longer works … (see above) … so the errors in the console come, when I open dashboard (maybe when it ries to convert it?)
I’ll look more into it ![]()
If I can somehow reproduce it on my machine, it’s easier to fix ![]()
By a crash of Firefox I lost contact with my 1st dashboard from here.
It’s impossible to get it back, even I have the link.
No switching lights. No quick look if everything is OK.
Waiting for the start of the new version or is my old one still there and I can wait to that.
Oops! had Firefox not right started. ![]()
Everything is OK.
I’m still using the “old” version, buit changes are not saved anymore. Is the new version still in development?
My first dashboard was made directly by github.
Sadly I can’t only use it under 1 browser. The one where it’s made in.
That browser I like to cleanup.
In the dashboard there is a link “save” but you cant edit the data there.
Copy/paste is so not possible.
Looking by github let me feel very stupid.
After filling things in I lost it directly in how to go further.
Remaking 50+ devices with there capability’s ect. again is no nice thing to look for.
Does your question relate to this Dashboards app? If so, you might want to ask your question in that topic.
If you read there you can see I did. Posts 1043 & 1050
That the new, experimental version, also difficult to is see.
Then I have to start all over again.
For a while no time for helping out others.
