ben ik weer, wanneer ik een flow wil maken en start met creality zie ik alleen de temp kaarten ik heb geen runout kaart gezien, heb ik iets fout gedaan of moet ik de app opnieuw downloaden en installeren? wederom bedankt voor al jou moeite
Change Log v1.1.15
Added support for Homey camera video streams on K1 Max, Hi, and Hi Combo devices.
The camera stream has been configured to reconnect when the printer’s IP address is changed.
The camera feed currently works only on the local network. Live video is not supported because Homey cannot convert the MJPEG stream via a WebRTC proxy for external network or remote access.
The issue where the print preview image in the Status widget would briefly disappear and reappear has been fixed.
A safety check has been added to the K1 Max, Hi, Hi Combo, and Generic Klipper control commands to display a clearer error message when the connection is not ready.
Change Log v1.1.17
Reliability fixes:** commands (pause/resume/stop/light/home) sent while the printer is unreachable now correctly report failure instead of appearing to succeed. Status polling now closes the connection as soon as data is received, restoring the intended fast on-demand polling behavior instead of holding sockets open for up to 4 seconds. Fixed a bug where finishing a print successfully could incorrectly fire the “Print stopped” flow trigger. Devices now properly stop polling and release camera resources when removed from Homey. Hardened the Status widget’s image proxy against being used to fetch arbitrary internal network addresses. Fixed the “press stop again to confirm” message disappearing instantly on Klipper/K1 Max devices.
Change Log v1.2.2 Test
Temperature control: read and set nozzle and bed target temperatures from the device or Flows. Layer tracking: new Current Layer and Total Layers sensors, shown in the Status widget, with a “Current layer is at least” Flow condition. Speed & flow control: new Print Speed and Flow Rate sensors plus Flow actions to adjust them (M220/M221). Fan control: new Flow action to set part cooling, case, and side fan speeds. Error reporting: new “Print error occurred” Flow trigger with the error message as a token. Hi Combo CFS: new Active Filament sensor showing the slot, material, and remaining percentage in use; slot overview now includes material, color, and remaining percentage per slot; fixed CFS values flickering to zero between updates. New CFS Filament dashboard widget with per-slot filament color rings, remaining percentage, active slot indicator, external spool row, and box temperature/humidity. Discovery: printers are now discovered automatically via mDNS during pairing (manual IP entry is still available). Connectivity: polling now backs off gradually up to 60 seconds while the printer is unreachable and recovers instantly. The K1 Max driver is now labeled K1 / Ender V3 Series, as all K1 and Ender V3 family printers running stock Creality firmware use the same protocol.
Yes, the camera feed should be visible. If you send me the diagnostic log, I can figure out where the error is.
Thanks. Log sent #580d9edf-15b4-43e1-8dcb-6cc26a82fe7c
Yes, the camera is supported on the Hi Combo device page, but only for local network viewing. In this case the logs show Homey cannot reach the printer at 192.168.1.230, so please verify the printer IP/network connection and test http://192.168.1.230:8080/?action=stream from the same local network.
Hi, the camera stream is on http://192.168.1.230:8000/ not port 8080.
Test v1.2.3
- Fixed camera streaming for Creality Hi and Hi Combo printers by using the correct
http://PRINTER_IP:8000/stream address. - K1 Max camera streaming continues to use port
8080. - Camera feeds are available only on the local network; remote viewing through Homey Cloud is not supported.
The log shows this is not yet a camera-stream error. The device has no valid printer IP:
Invalid printer IP address
In the Homey device settings, enter:
IP Address: 192.168.1.230
Port: 9999
Do not enter http://192.168.1.230:8000/ in the IP field. The app automatically uses port 8000 for the Hi/Hi Combo camera.
After saving the settings, restart the app or re-add the device if the IP remains empty. Camera viewing is available only on the same local network.
Could you test it and report the result again?
After launching the application, open the camera screen, wait 10-15 seconds, and capture the log generated during that time
