[APP][Pro&Cloud] Shelly
Was fixed on my side since last update.
All good for you as well?
I have problems with the detached switching:
I have a few Shelly relays (like shelly 1 mini gen 3) that are currently physically switching smart lights (e.g., Shelly GU10, Wiz), but I’d like to decouple the switching and control everything via Homey over the local Wi-Fi network.
In the Shelly app, I tested the “detached” mode with a GU10 spot, and it works as expected. However, I have a room with over 20 LEDs, and I also need to control a few 3rd-party devices.
All devices have fixed IP addresses and are added to Homey. I can control both the relays and the lights from the Homey app and via flows.
The issue is: when the wall switch is pressed in “detached” mode, it doesn’t trigger anything in Homey — the lights don’t respond.
I tried using a webhook from the Shelly to trigger a Homey flow, and it worked.
So I started setting up the next room, but then it stopped working even in the first location.
When I open the webhook URL in a browser, it returns “OK” (but the light don’t change), the flow is triggered in Homey, in the shelly log appaers the switch action.
One thing I’ve managed to set up successfully: a long press on the switch directly toggles the relay (as a fallback) — in case Homey or the Wi-Fi network is down.
So
 what am I missing? What could be going wrong?
The MQTT is hard for me at this step. So I would like to use it with this app, or with webhook.
Now it works with webhook.
The question marks “?” have somehow been transformed into “/” in shelly devices. So the webhook url was not correct.
But I don’t know why don’t work (or how can I use) this card :red_question_mark: :confused:
All my Shellys are no longer available since the last update of Homey pro, what can I do?
What do you mean by ‘no longer available’? Do the device tiles show a red exclamation mark?
Did you try to restart the Shelly app on your Homey?
All my Shellys are online
You have a nice collection :sweat_smile: !
I have also been running into problems with my Shelly devices not communicating back for example the temperature info to Homey, but I can still for example control switches on and off. No error messages are shown in Homey.
In the Shelly app (not the Shelly app in Homey) everything works as normal.
I have tried restarting the shelly app, the various sensors as well as power cycling my Homey and so far nothing has improve the situation.
update
All shellys were gone for more than a day both in Homey and in Shelly’s app, restarting the app or Homy had no effect.
Later in the day the devices started connecting one by one and after about 3 hours all the devices (18) were up and working.
That’s strange.
My Shelly H&T sensor is not always updating. In the picture you can see the last update was 24 days ago. Is there any setting to solve this?
Possible solutions:
  • restart Shelly app on Homey
  • restart Homey
  • Is it battery driven? Check battery; my H&T 3 has an e-ink display, which can show the temperature, even without or empty battery. In that case the sceen won’t update anymore and won’t send data to Homey.
  • On the backside of the device is a reset button, push it
  • reboot device in Shelly app
I ended up removing all my H&T devices from Homey and adding them back. This seems to have fixed the problem, at least for now.
Thanks for the info
i fear the device is “dead”. I put in a new battery but it didn’t start blinking. Maybe it died because of the high temperatures in the greenhouse.
i just bought 2 shelly 1pm gen4 device and 2 addOn with each 2 db18 temp sensor
i can connect the shelly by zigbee to my network but i don’t see the temp sensors if i put the addon to it.
what am i doing wrong?
Try connecting the Shelly via WIFi instead of Zigbee (remove the Zigbee device, then add it as ‘any Shelly WiFi device’).
Thanks for the comment, i did not try that because the place where i need the sensor has no wifi.
Ah okay, but that location provides a strong enough Zigbee network? Dit you pair the Shelly device to your Homey at that specific location, or closer to your Homey?
i did pair the device at the specific location, and i do have a zigbee connection over there. (it’s in a cellar) but my wifi does’t have a connection there.
but by zigbee i don’t see the probes.
if i connect by wifi in annother room in the house i can get it working with the addon and then i see the temp from the probes. but als mention i don’t have wifi in the cellar.
so that is way i prefer zigbee otherwise i need to buy another accespoit
Thanks for clarifying; I wasn’t sure.
Seems strange indeed. Maybe the add-on is not yet (fully) supported via Zigbee.
Shelly’s Homey app is maintained by Drenso (see also first post).
Suggest you reach out to them, via the indicated e-mail address. My experience is that they respond fairly quickly.
thanks for the respond, should have tought of that my self. (i meen to reach out to the developer)
