After update to 3.11.3 the Shelly EM3 lost connection. Homey version 8.0.3.
Tried restarting app and restarting Homey and updating Homey to 8.0.5. Nothing have changed in the locan wlan. After restarting the app the device works for about 30s and the power and energy is updated. After that the connection is lost.
Shelly cloud app can connect to the device.
Anyone else have same problems?
Diagnostic code after app reset and disconnection. 07c24e92-b1d1-411d-9b74-31653841eb10
After yesterdays Shelly update 3.11.3 my RGBW2 stopped working with my homey.
It doesnt want to power on my lights. It works flawlessly with Shelly and Shelly home apps, but not with Homey.
Ive tried the following:
Remove the device and add it again.
Restarted the app and also Homey.
Ive even tried version 3.11.4, but with no luck.
It looks like you have not removed all channels of the RGBW2 before re-adding the device with the new driver. Make sure you remove all channels before re-pairing.
I have removed all channels before re-adding the device.
I have even tried to a factory reset on the RGBW2. But no luck.
It seems that if i start/stop one channel on the Shelly app. Homey will show correct status (it shows power consumption and so on).
But I cannot turn the device on/off in the homey app.
If I for example turn it on, on Homey, it will show “Turned off by Shelly” right after ive started it in the History tab.
For Plus/Pro devices this is mandatory. Support will be removed sometime early september. For first generation devices it’s not necessary but recommended. I hope to remove all the old drivers at some point and reduce the footprint of the app. It’s huge at the moment.
Since a few days I can not use my Shelly 1’s anymore via homey. In the shelly app they work like normal. Button press does not activate anything and also the switch input is not detected.
my Shelly 2.5 work fine
But: both 1 & 2.5 get the orange notification that they will not be supported in the future.
How can I fix this?
Sorry if the topic was maybe raised already… long forum…
my app version is V.3.11.5 on Homey Pro
Shelly’s are updated with latest firmware.
I have shelly 4pm and get it up in Homey, but when I turn on output 1 then all the outputs come up as on, but if I physically look at shelly then only channel 1 is on. When I turn on e.g. output 3 then it works. It’s only when I turn on output 1 in Homey that all the outputs show on, but only output 1 is really on
