[APP][Pro&Cloud] Shelly
Can you send me a diagnostic report and send the output of http://<<shellyuni_ip>>/status and http://<<shellyuni_ip>>/settings.
Hi Jelger,
Here I send you the requested info about the Shelly Uni (that does not update the adc voltage in Homey):
Status:
{"wifi_sta":{"connected":true,"ssid":"VitalNet","ip":"192.168.1.106","rssi":-66},"cloud":{"enabled":false,"connected":false},"mqtt":{"connected":false},"time":"22:40","unixtime":1626468048,"serial":7,"has_update":true,"mac":"8CAAB54B6882","cfg_changed_cnt":0,"actions_stats":{"skipped":0},"relays":[{"ison":false,"has_timer":false,"timer_started":0,"timer_duration":0,"timer_remaining":0,"source":"input"},{"ison":false,"has_timer":false,"timer_started":0,"timer_duration":0,"timer_remaining":0,"source":"input"}],"inputs":[{"input":0,"event":"","event_cnt":0},{"input":0,"event":"","event_cnt":0}],"adcs":[{"voltage":0.03}],"ext_sensors":{},"ext_temperature":{},"ext_humidity":{},"update":{"status":"pending","has_update":true,"new_version":"20210429-102528/v1.10.4-g3f94cd7","old_version":"20210702-123638/v1.11.0-rc2-g7766530","beta_version":"20210702-123638/v1.11.0-rc2-g7766530"},"ram_total":49376,"ram_free":36828,"fs_size":233681,"fs_free":147337,"ping_check":true,"uptime":155}
Currently a beta version of firmware installed. Previous version gave the same issue.
Settings:
{"device":{"type":"SHUNI-1","mac":"8CAAB54B6882","hostname":"shellyuni-483FDA82C0E0","num_outputs":2},"wifi_ap":{"enabled":false,"ssid":"shellyuni-483FDA82C0E0","key":""},"wifi_sta":{"enabled":true,"ssid":"VitalNet","ipv4_method":"dhcp","ip":null,"gw":null,"mask":null,"dns":null},"wifi_sta1":{"enabled":false,"ssid":null,"ipv4_method":"dhcp","ip":null,"gw":null,"mask":null,"dns":null},"ap_roaming":{"enabled":false,"threshold":-70},"mqtt": {"enable":false,"server":"192.168.33.3:1883","user":"","id":"shellyuni-483FDA82C0E0","reconnect_timeout_max":60.000000,"reconnect_timeout_min":2.000000,"clean_session":true,"keep_alive":60,"max_qos":0,"retain":false,"update_period":30},"coiot": {"enabled":true,"update_period":15,"peer":"192.168.1.105:5683"},"sntp":{"server":"time.google.com","enabled":true},"login":{"enabled":false,"unprotected":false,"username":"admin"},"pin_code":"","name":null,"fw":"20210702-123638/v1.11.0-rc2-g7766530","factory_reset_from_switch":true,"discoverable":true,"build_info":{"build_id":"20210702-123638/v1.11.0-rc2-g7766530","build_timestamp":"2021-07-02T12:36:38Z","build_version":"1.0"},"cloud":{"enabled":false,"connected":false},"timezone":"Europe/Amsterdam","lat":52.277000,"lng":4.747130,"tzautodetect":true,"tz_utc_offset":7200,"tz_dst":false,"tz_dst_auto":true,"time":"22:43","unixtime":1626468234,"debug_enable":false,"allow_cross_origin":false,"actions":{"active":false,"names":["out_on_url","out_off_url","btn_on_url","btn_off_url","longpush_url","shortpush_url","out_on_url","out_off_url","btn_on_url","btn_off_url","longpush_url","shortpush_url","adc_over_url","adc_under_url","ext_temp_over_url","ext_temp_under_url","ext_temp_over_url","ext_temp_under_url","ext_temp_over_url","ext_temp_under_url","ext_temp_over_url","ext_temp_under_url","ext_temp_over_url","ext_temp_under_url","ext_hum_over_url","ext_hum_under_url"]},"hwinfo":{"hw_revision":"prod-202008", "batch_id":0},"mode":"relay","longpush_time":800,"relays":[{"name":null,"appliance_type":"General","ison":false,"has_timer":false,"default_state":"off","btn_type":"toggle","btn_reverse":0,"auto_on":0.00,"auto_off":0.00,"schedule":false,"schedule_rules":[]},{"name":null,"appliance_type":"General","ison":false,"has_timer":false,"default_state":"off","btn_type":"toggle","btn_reverse":0,"auto_on":0.00,"auto_off":0.00,"schedule":false,"schedule_rules":[]}],"adcs":[{"range":30,"offset":0.00,"relay_actions":[{"over_threshold":0,"over_act":"disabled","under_threshold":0,"under_act":"disabled"},{"over_threshold":0,"over_act":"disabled","under_threshold":0,"under_act":"disabled"}]}],"ext_sensors":{},"ext_temperature":{},"ext_humidity":{},"wifirecovery_reboot_enabled":true}
Diagnosic report id:
35b4c360-2fe4-4a79-ae72-22ccfd6b70be
Hope this gives you the info you need. If not, I can send you more!
Kind regards,
Tycho
v3.0.51 - 2021-07-17
  • Possible fix for reading ADCS for Shelly Uni
This solved my issue!
Many thanks!!
Shelly app stopped working for me after update? Anybody with similar issue? Mobile app of Shelly is ok, but Homey app is just dead, I can go and see my devices but can’t add any and it wont turn off or on any devices. It does not give me any error, visual icon looks like the light is turned on, but it isn’t. I can turn the light via mobil shelly app.
also not working for me anymore. on the “Apps” page in homey it shows up with a pause icon next to it. Any Idea?
App version 3.1.1
Homey Version 7.1.0
Same here, everything stopped working 6hrs ago after update to 3.1.1
f3815bd3-610e-43ac-8843-fcd42b53c73f
I had the same problem. Dont reset it via reset button but just unplug Homey for a minute and plug back in. worked for me
I did a homey reboot. That is what you did too
 The app has a pause symbol
Jup
 The update broke also broke my Shelly app. Also 3.1.1 with Homey 7.1.0. The app jumps to pause everytime. Devices are unavailable (red exclamation mark). Homey restart didn’t work.
@Phuturist any ideas?
Just unplug it.
Ok, i’ll try that.
Unplugged 2 minutes
 no change
You all are on the test version of the app. Things might break, that is what testing is for. I’d appreciate it if anyone can send a diagnostic report so I can actually do something about it.
To fix your issue, just install the regular app store version.
I did :wink:
Before unplugging homey, just a reboot
After unplugging for 2 mins
34eafb93-0440-4a9c-ab12-4e17e230b50f
A fix has just been published to the test channel. Please let me know if there are other issues with this test version.
Thank you! Works again
I changed to the experimental channel when we were struggeling with the new coap system. As removing the app to reinstall again from the regular channel requires reconfiguration of all devices and flows
 which will take a whole day in my case
 I just disabled auto update. Will do that ad hoc when required :wink:
This is not the case. You can just hit install from the regular app store version and it will install it without having you to re-pair or re-configure flows.
I’m looking for a energy meter for my heat pump and I’m thinking about the Shelly 3EM, because the heat pump uses 3 phases. When the 3EM is connected to Homey, is their a possibility to link the power usage to my heat pump device in Homey (as I also have a device in Homey for my heat pump).
Or will it just create a new device and no linking possibilities to a existing device?
Thanks
– Erik
