Hi @RM_de_Gruijter, thanks again for 2.2.1. Feedback so far:
- Remote control works. With “Ignore export limitation” on, Homey mode is accepted. Homey +500 W charged the battery at a steady 495–500 W, and switching to Self-use stopped it cleanly and reset both limits to 11,400 W.
- The warning appears when a Homey-run mode is set and clears on Self-use, as you described.
- With “Ignore export limitation” off, Homey mode is refused with the export limitation message, so 2049 is handled as you intended.
I’ll keep testing and let you know how I get on
Hi @RM_de_Gruijter , I’ve now tested more of 2.2.1 on the SE5000H, with “Ignore export limitation” on:
- Force discharge works. One thing I noticed: as the solar faded, the battery raised its discharge from 2.6 to 4.1 kW so that export stayed at almost exactly 3.88 kW, about 78% of the inverter’s rating. So the inverter limits export to about 3.9 kW even with “Ignore export limitation” on. That’s fine for me, but worth knowing if others expect the setting to lift the inverter’s own limit.
- Charge from solar only and Backup didn’t charge from spare solar. With 0.3–1.3 kW of solar being exported and the charge limit at 5,000 W, the battery stayed at 0 W in both modes. Switching back to self-consumption, it charged straight away from the same spare solar. So on this inverter, Charge from solar only seems to use SolarEdge’s “excess PV” meaning, solar the inverter would otherwise clip, rather than the surplus over house load. It might be worth saying so in the card’s hint.
- One oddity: switching to Backup gave a 10-second burst of charging at exactly 1,000 W, then 0 W, twice.
A further request: could you add a Homey-run self-consumption mode, i.e. SolarEdge remote command 7 “Maximize self-consumption”, that honours the maximum discharge power? Self-consumption with a 0 W discharge limit is how I hold the battery during the day: it charges from spare solar but saves its charge for the evening peak. The other app does this today through the default mode and discharge limit, and it’s the one piece I’m missing to move my battery control to your app.
Thank you again!
Thanks for testing, very useful!
- Export at ~3.9 kW: export limitation still applies. The setting only allows battery control while it’s on. I’ve corrected its hint.
- Charge from solar only: you’re right, it only used solar above the inverter’s AC limit. In the next version it charges from spare solar and doesn’t discharge.
- Backup is the inverter’s own mode; the app sends nothing there.
- Your request: the next version has a new mode “Self-use, max. power”. It follows the “Set maximum discharge power” card, so 0 W holds the battery during the day, as you do now.
New version 2.3.0 is ready for testing:
- Added battery mode Self-use, max. power.
- Charge from solar only now charges from spare solar
- Minor other fixes and improvements
Hi Robin, I’ve now tested 2.3.0 fully on my SE5000H (firmware 0004.0024.0014, “Ignore export limitation” on), and everything works. Thank you for turning these round so quickly.
- Self-use, max. power with the maximum discharge power at 0 W does exactly what I needed for my daytime hold: the battery charged from spare solar (following the surplus, grid near zero) and never discharged, even while the house was importing. That was the last piece I needed to move my battery control to your app.
- Charge from solar only now charges from spare solar too
- Homey ±1,000 W, Force charge (up to 5 kW) and Force discharge all work. Setting the maximum discharge power to 0 W in Force discharge stopped it within a second.
- An hour in Homey mode at −500 W, with an app restart halfway through, held without a gap, so the command resumes nicely after a restart.
Thanks again, now to go and rebuild a bunch of my flows!
Hi Im getting weird issue, if I open batery Im getting empty selection
If I change anything in the first tab then Im getting warning with some general text like contact your admin
And now it’s started to being weird because I have to open mysolaredge app and change settings because my battery discharge max 0.08kwh, codex analysed modbus and read that for some reason my battery was switched to charge from pv+ac
Here are my settings from mysolar
Question by PM: can Homey control a SolarEdge hybrid inverter and battery (charging, discharging, grid export) based on electricity prices?
Hi @Jan_Dirkx ,
The action cards do exist, but only for the Modbus devices, not the cloud devices. With Modbus you can choose the battery mode in flows (for example self-use, force charge/discharge, or charge from solar only) and limit grid export. Your installer has to enable Modbus TCP in SetApp first.
While Frank Energie controls your battery, it’s better not to control it from Homey as well, or the two will get in each other’s way.
If you only want to use as much of your own solar power as possible, mode 2 does that fine without Homey. Homey is mainly useful if you want to act on electricity prices.
An empty mode means your inverter is in remote control, but not by Homey. Did Codex or anything else write to the inverter?
Select “Self-use” in Homey to set it back.
If it happens again, please send a diagnostic report
