[APP][Pro] BLE Climate Sensors
I am presenting my new unified BLE Sensors app.
Currently this app supports:
ThermoBeacons
  • Lanyard mini Thermo Hygrometer
TempPro Devices
  • TP350
  • TP351
  • TP357
  • TP357S
  • TP358
  • TP359
  • TP393
  • etc.
There are more devices to come. The TempPro support is generic so if your device uses the same protocol as other already supported models your chances are high that it will be supported too.
Here is the test version:
For feedback, I’m unable to connect both TP351S and TP357S.
The other app (Thermpro app homey) TP357S can be connected.
Did you try to connect multiple times? Was the device not listed or it just could not be added? Can you do a diagnostics report?
I implemented a fix to ease the strict model check in the ThermoPro driver. I hope it works now for you. Due to the lack of alternative models my testing capabilities are a bit limited. I ordered a TP351S for testing but until it arrives I am a bit limited. :slight_smile:
Yes, now i can add both the TP351S and TP357S. i’m going to check if everthing works oke!
Great work!!
New Update: v1.6.0
  • Added support for Meater temperature probe
  • Renamed app to resemble enhanced ecosystem
Meater support is for the Bluetooth base of the probe as it works like a relay for the temperature probe. The meater device in homey supports a target temperature and calculates the remaining cooking time in 5-minute windows. The calculation is not very accurate as the external factors are unknown (like meat type, thickness, etc.) but it should help to have a flow that can warn you when cooking time reaches like 5 mins remaining etc..
