[APP][Pro] BMW Connected
Thanks, you’re right, that solved the issue! :blush:
Maybe Athom can take a look at this bug…
I can’t login in the app while I’m adding the car. I’m using the same login details on My BMW, but it doesn’t work in your app. Can you please help my what I’m doing wrong?
b465d20d-2a2e-4cab-b140-ac5778714fa3
You need to use the test version of the app. Please read the first post in this thread. BMW has blocked access to the ConnectedDrive API. You need to setup cardata and then can login using your generated clied id.
I still get the authentication error after inputting my client id:
I am on version 1.0.11. I did follow your link to the test version, but it redirects me to the URL that does not have the /test path. It also does not say Experimental in the app.
Authorization Failed
Error: Failed to request device code: Failed to connect to OAuth server
Hi, everything works fine for me. bit I had 2 questions :
Is location still available.
can I use the associated flowcards (geofence, climate, …location) in flows?
Hi Likhan,
Thank you for being so adaptable and keeping your Homey app alive.
I see that only BMW EU owners can use the app presently. As a USA owner, would you consider adding the BMW USA portal?
Thanks very much,
Hugh
I used to have this kind of flow in old version of app.
In the new one, the climate now function is only visible in “when” tab but not in “then” tab. Any idea how to make it work again please? Thanks in advance for your help.
I get this message constantly and I not able to get connected with BMW CarData. Does someone know how to solve this issue?
Hi all trying to register my BMW to the app, trying to go to the customer.bmwgroup.com/cardata page but it kees saying this page doesnt exist, what am I doing wrong? thanks Bart (PS located in the Netherlands)
Nevermind…… should have read the start of this post better
I can not even get the cardata part to work. I get different customer IDś and none of them work.
Is there a simple guide to set this up ? Thanks.
first post → link to the github should help (step by step) com.rexwel.bmwconnected/README.md at main · lsiddiquee/com.rexwel.bmwconnected · GitHub
Thanks. I am stuck at “waiting for authorisation” after entering the code.
which version are you using? i’m currently on 1.0.13 test version and it works fine
It now works, but i received a time-out several times before it accepted it.
Thanks for the help !
PS: I am using version 1.0.11
I have the exact same, cannot get beyond this point.
Did you already mange @Roy_Derksen ?
Same here :frowning:
With 1.0.11 I never gets past the “waiting for authorization”. Always times out.
With 1.0.13 test version I get an error: “Failed to create container. HTTP error 403: Unknown error.
I also get stuck on the Authorization. I follow the link and enter the code, the page tells me “LOGIN SUCCESSFUL”. However, when I get back to Homey it tells me Authorization Failed.
I read in the “Readme.md” that user mapping needs to be “PRIMARY”. I have only one car registered, so I assume it would be the primary? Where can I double check that?
Also, I do see the Client ID under “Car Data API” but didn’t “Authenticate Device”:
Could that be the problem? (Was hoping that the BMW Homey App would take care of it, since I don’t understand the steps…)
