[APP][Pro] BMW Connected
Most of the basic functionality now should be working. Please start testing the version in test and provide feedback in the github issues. Thanks
@Likhan In Card Data Stream block which data points we need to select?
I have selected all the keys, but for now the following keys are primarily what is being used in the app:
  • vehicle.vehicle.travelledDistance
  • vehicle.driveTrain.lastRemainingRange
  • vehicle.cabin.infotainment.navigation.currentLocation.latitude
  • vehicle.cabin.infotainment.navigation.currentLocation.longitude
  • vehicle.cabin.door.status
  • vehicle.driveTrain.batteryManagement.header
  • vehicle.driveTrain.electricEngine.kombiRemainingElectricRange
  • vehicle.driveTrain.electricEngine.charging.status
  • vehicle.powertrain.electric.battery.stateOfCharge.target
  • vehicle.driveTrain.fuelSystem.remainingFuel
My car was successfully added, and it’s now streaming data. I’ve started testing the app, and it looks good so far. Thanks a lot for your awesome work! :slightly_smiling_face:
The battery information is not updated as frequently when charging (It updates once in every hour or so when connected). I think it might be intentional, as the whole charging control is what triggered BMW blocking API access extensively.
I don’t understand. My login appears failed. But it’s the good one because I can enter Mini site et see and select car data. But on Homey, I’ve got a failed identification. The identification is back to what it was weeks ago (login/password/region) or is it like in V1.x.x with the long car data code ?
I did it. simply uninstalled and installed again… Strange becasue the app had the new number (1.0.4) and was uodated… Whatever. It works !!
Got 1.0.4 to work as well after a few attempts. Could not configure the authentication with the passcode in the app on my iphone, but it worked from the web interface on my computer.
Looking for more data over time. Charging speed in kW would be awesome.
Thanks for updating the app :slight_smile:
How do I install the newest version?
I have “automatic updates” switched on in the App, I also tried uninstalling and re-installing, but my BMW App keeps to stay on version 0.7.9.
How do I get the latest release?? :man_shrugging:t2::weary_face:
This post [APP][Pro] BMW Connected - Apps - Homey Community Forum has the links to the latest released version and the latest test version
I get this terror after inputting the Cardata client id. I copied it so I know there should not be any spelling mistakes. Access to Cardata API has been toggled on, so has Cardata streaming.
If you had the app running earlier it might be due to quota exceeded. Please disable the app for 24 hours for the quota refresh then try again.
Ah, good tip! I did have the app running from earlier, so I have removed the device and will re-add it tonight and test.
I’m sorry but I can’t find “repair”. Is that in Homey or MyBMW?
Tim
Repair is in Homey for the BMW/Mini device.
Tonight, v1.0.5 was installed, and I tried to repair the device, but the login failed on both the Homey web app and iPhone.
v1.0.4 was working flawlessly.
BTW do you have a direct link to report this in Github?
Indeed just checked it is broken. Will take a look and try to push a fix asap.
Just forced the update… V 1.0.7 seems to work here with my 2 cars… but the informations I received are not all those I selected on car data web site. What I’d rally like is the charge programm and the pre-heat.
But it’s already cool !
Solved with v1.0.7, thanks!
