[APP][Pro] Blink for Home - Smart security designed for every home
If it’s Windows credentials, it’s a SMB on your Windows PC? And you tried to access the SMB from inside Windows?
Homey comes from outside. The most possible reason is the Windows firewall I think. Can you check if this is logged?
Hi, I did a quick test with the Windows firewall off - same error.
I am am running a Homey-shs running with a VM on the same Windows hardware. THat’s why I said I could connect to the share via linux SMBCLIENT in the VM console and read/write to the share.
I can access the share from another windows machine using the same credentials…
@RonnyW I’m seeing the same login failure on Homey Self-Hosted Server 13.5.3 with Blink for Home 2.1.8. When adding the Account device, the app immediately says ‘The login data is invalid!’ after entering the email and password, before it asks for a 2FA code. The account owner confirms the credentials are correct. Restarting the app and a clean uninstall/reinstall did not change it. I sent an app diagnostics report just after reproducing the error: 2b31b7fa-579a-43fc-a1ae-5ab5cc3c95f7. Could you check the OAuth response/cookie handling? This looks similar to the SHS report in posts 390–395. Thank you.
New test version 2.1.9:
  • Fixed Blink API change (device ID UUIDv4 format).
It’s a default http 406 error (Not Acceptable). It seems, Blink changed the device ID check.
I made an update to use UUIDv4 format. For me it’s working. Please check if the new test version is also working for you. Thanks for the hint.
Hello, I noticed that my Blink for home account was throwing API errors. I wrote a quick flow to trap the error:
20-11-2026 09:46 BLINK for Home error - ✓ reason - Reading motion/video data (SyncModule): Cloud Usage: 100
Nov 20 2026 09:46:49
2 minutes ago
20-11-2026 09:45 BLINK for Home error - ✓ reason - Reading motion/video data (SyncModule): Cloud Usage: 100
It seems your cloud storage is full and the API throwns an error. Try to delete some videos in your cloud storage (Blink mobile app) to get some free storage space.
But that’s Blink internal, not Homey related.
Howdy,
I did cleanup the cloud storage, but the errors continued? I have an original BLINK SYNC module - could that be related?
20-11-2026 17:53 BLINK for Home error - ✓ reason - Reading motion/video data (SyncModule): Cloud Usage: 1
45 minutes ago
20-11-2026 17:52 BLINK for Home error - ✓ reason - Reading motion/video data (SyncModule): Cloud Usage: 1
45 minutes ago
46 minutes ago
46 minutes ago
20-11-2026 17:51 BLINK for Home error - ✓ reason - Reading motion/video data (SyncModule): Cloud Usage: 1
46 minutes ago
47 minutes ago
47 minutes ago
47 minutes ago
20-11-2026 17:50 BLINK for Home error - ✓ reason - Reading motion/video data (SyncModule): Cloud Usage: 1
47 minutes ago
48 minutes ago
20-11-2026 17:49 BLINK for Home error - ✓ reason - Reading motion/video data (SyncModule): Cloud Usage: 1
49 minutes ago
49 minutes ago
20-11-2026 17:48 BLINK for Home error - ✓ reason - Reading motion/video data (SyncModule): Cloud Usage: 1
50 minutes ago
50 minutes ago
20-11-2026 17:47 BLINK for Home error - ✓ reason - Reading motion/video data (SyncModule): Cloud Usage: 1
51 minutes ago
51 minutes ago
51 minutes ago
20-11-2026 17:46 BLINK for Home error - ✓ reason - Reading motion/video data (SyncModule): Cloud Usage: 1
51 minutes ago
52 minutes ago
20-11-2026 17:45 BLINK for Home error - ✓ reason - Reading motion/video data (SyncModule): Cloud Usage: 1
52 minutes ago
53 minutes ago
20-11-2026 17:44 BLINK for Home error - ✓ reason - Reading motion/video data (SyncModule): Cloud Usage: 1
54 minutes ago
20-11-2026 17:43 BLINK for Home error - ✓ reason - Reading motion/video data (SyncModule): Cloud Usage: 1
If it’s a standard SyncModule (without USB), try to deactivate local storage check. Perhaps this combination is causing the issue. I will check later where this error could come from.
You can also send a diagnostics report. Perhaps I can see the root cause there. Thanks.
Hi, I am not using local storage, no USB drive plugged in. I could not find any setting in the BLINK app to deactivate local stg check. I did grab a diagnostics report from the BLINK from home app - df20d753-feb4-46a1-b5c0-688bd3951b01
Hi, your log shows http 400 errors while trying to read videos from.the sync module.
You can deactivate polling local storage in account device settings.
…and perhaps I can find a way to check if the SyncModule has storage or not…just for preventing unneccesary errors.
I was able to turn off the error in the homey blink for home app. This a screenshot of advanced settings
(attachments)
New test version 2.1.10:
  • Skip SyncModules without active storage on video check.
This check excludes SyncModules from video check where no storage is present or inactive.
Hi Ronny, Thanks for the quick response. I installed the app update. I still am having having timeout issues, but no API errors after resetting the advanced settings for the Blink for home Account…
I did some extra testing by changing the the share name to something wrong ; An immediate “export error”. The same thing for a bad user name or password.
I have noticed that the Blink app itself takes several seconds to load a clip to view. I get a message from BLINK saying “Getting your video ready. Almost ready”. The clips are 30 seconds at standard quality…
Where exactly do you get timeouts? “Exports” means SMB? Can you reproduce the issue in an AdvancedFlow?
Keep in mind, that you can’t just call the SMB export flow card without a video parameter. Do use the “request video” flow action to create a file. Then use the “motion alert” trigger to store the file to SMB/FTP. Use the video ID token to grab the correct file.
Then use the error outputs on both cards and write a timeline entry with the error message.
If this happens, please send me the error message and where it happened (which flow card).
Thanks.
Hi Ronny,
Thank you for being patient with me and responding so quickly.
I took your suggestion and created a an advanced flow - I used saved liveview after the flow did not get triggered with a “motion was detected”. Both did no
t set started!
