[APP][Pro] Better Logic Library - Just some better logic, variable and library management
Okay, off to bed, but first: update in test!
The date expression now correctly takes the second argument date from a string or number (and ofc a real date object).
When it’s a number it will be handled as the UTC tick.
If it’s a string based 2022-11-09T04:13:59.813Z it will also be handled correct.
So, now you can use the new Execute BL Expression (as tag f.i.) and have an Insight or other saved dated converted into real dates within flows:
