Unfortunately restarting the AsusWRT app multiple times didn’t help…
After that I also updated Homey to v8.0.4, so a restart of Homey was performed as well.
Tried to restart the AsusWRT app twice again in the pas few minutes, but no luck either. Sorry…
I sent you a diagnostic report, hope that helps a bit?
20e8f65b-b27c-46eb-a869-253a989a3ec0
Ehm, sorry, not sure what you mean here. When I tap (i.e) the icon for the total of connected devices, nothing happens other than showing how long ago the value was updated. That is the same for all icons…
Just found this app a few days ago and really like the possibility to use phone connected to router as a trigger for arming/disarming a home security system.
I did a test flow that monitors when my iPhone is connected to my Asus router and sends me a notification when it’s connected and disconnected.
This was a bit disappointing since it turns out that my phone disconnects (and immediately connects) now and then even when I’m just sitting still in front of the TV. If I move around the house it happens more often.
According to the wifi symbol on the phone I have strong signal everywhere, even in my garden…so this should not be a signal issue.
One thing I’m thinking of is that I have a mesh system with two Asus RT-AC86U and maybe the phone jumps between the two and that triggers the “Went offline” and “Came online” cards?
Anyone that have experienced the same thing?
Creating an automated arming/disarming of a home security system using this method would not be that good since the burglar alarm would be triggered by myself when I’m home!
Great that you found the app, but I don’t think you have an issue with the app itself, but with your Iphone.
The router always returns all devices connected to the network, so it shouldn’t be necessary to check each access point if the device roamed to that device. As of right now, I have a trigger on my main router with ‘went online’ and ‘went offline’ to check if my phone is in the house, but I see that my phone is connected to one of my Access points at this moment.
But, if you think I’m wrong, you could do something like this and check both your main router and access points if you can find the device over there:
I am still figuring things out regarding the capabilities (and also holiday stuff) so it took me a little longer but a new version is coming soon, hopefully before october.
You have to manually add your access point devices the same way as you added the main router. If you go to your asus web portal on your computer and to AIMesh settings you are able to check the IP of your access point, use that IP to add your access point to your homey.
I have not yet figured out how the Asus android app finds all ai mesh devices automatically so I haven’t been able to implement that (yet).
Reverse engineering the android app is a tedious and time consuming process I am afraid…
Thx again for the hard work.
The Dutch translations seem fine to me!
I do still see some values double. One of them is updated, the other not, it seems. Don’t know if you worked on that too…
Have 3 ASUS ZenWiFI AX, added them with respective IP and signed in with admin account on each. I can add them fine, but get error on all 3 of them and from what I can see there is no data coming to Insights, for example, connected devices etc which would confirm that I have a working setup.
That should not happen…
I would like to ask you to restart the asus app from the homey app settings and wait 5 minutes. If you could then use the button to ‘send error report’ for the Asus app that would be a great help!
Thanks for being a user. I have added your request to the github issues, however, I can not promise this will be in the app anytime soon due to the reverse engineering proces required to implement any feature at the moment.
The running time is something that I will look into. The benefit of having it in seconds is you can do any conversion with it yourself in the flow cards, but I do understand it is unreadable from a user perspective. I might add a seperate capability with a readable format.
@SlicingHaunt
There seems to be a bug with Aimesh: shown Online Devices
I got 3 routers set to Aimesh, my main router shows the correct Online Devices, second node always shows 12 (it only got 1 device) and third node is always at 34 Online Devices (IRL its around 5).
