[APP][PRO] Apollo Automation
Yes, some of our devices have CO2 sensors preinstalled, and the value shows in our Apollo Homey app.
Hello Everyone Has anyone brought on an Apollo Air 1 Air Quality Sensor into Homey Pro? How did you do it? w videos for Home Assistant and ESPHome, but none for Homey yet. Thank you
Just how one should install any other device on Homey I guess (sorry if that was a part of your question as well):
Make sure the sensor device is reachable from your network;
install the Apollo app (https://homey.app/en-nl/app/com.apolloautomation/Apollo-Automation/);
add a new device;
select the Apollo app;
select the “Every Apollo sensor” device
and follow instructions
Hey hey hey! Thanks for thinking of us! We have a Homey guide on our Apollo Wiki which I have linked here: Getting Started - Apollo Docs
But basically what @Peter_Kawa said. Haha!
Let us know if you need anything else!
Thanks for helping the community!
We have an Apollo Wiki for Homey here: Getting Started - Apollo Docs
No problem! Didn’t know about the wiki yet, I see it’s already mentioned @ topic post # 1.
Have a good one
Hello Everyone
Thank you
It might be better to ask it in the Apollo Automation app topic, since the developer and other users are also active there:
Hello! Thanks for your support! We have an Apollo Wiki with guides here: Getting Started - Apollo Docs
It goes through al of the installation steps. Please let us know if you need anything else!
I have an R1 Pro that was working great on wif. However, ive now connected it via ethernet poe. Now when I add it to homey it gives 2 identical devices I can add (but can only select one in the process). It doesnt matter which one I choose but in both cases the unit is only added with the light control. All other sensors arent exposed. Have already reset and deleted and reinstalled the app. Maybe something in the ethernet firmware?
Thanks for your support! Let me look into this. I’m actually in Enschede and visited the Homey office yesterday. I might be able to update the app and test it while I’m here. Haha! @Doekse
New test app is live! Let us know how it works! @Doekse
Didnt solve my poe issue. Still 2 devices i can add but neither exposes anyting but the led.
You’ve probably already done this, but I just want to double-check. Did you do a full uninstall and reinstall of the app and the device? Then please confirm you’re on the test app.
Thanks again for your help! I can now find the device (sry had to reinstall to get the test version which conflicted with the previous version apparently) but it now hangs on this screen.
Thanks for troubleshooting. Does it find the device again, but it stops you from adding it?
Yes it finds it perfectly. But gets stuck on the screen i shared. I can cancel out of it but then nothing was added. Waiting also doesnt work.
Try the updated test app, please. It should be fixed now.
It works now! Great support thanks so much!
That’s great to hear! We’ll get it pushed to the main app soon!
