yes
and the devices do not appear. only the echo is present
Hello Jamie,
Thanks for this great app, it works like a charme for me ![]()
I have a question regarding the Condition above, you crossed out the text. What does it mean? We wonât have this condition? Or youâll develop another equivalent condition?
Thanks again for this app.
Regards,
Moussa.
Hello Jamie,
Thanks for a great sounding app. It sounds great, but I have been able to get it to work longer than 10-15 minutes.
I can configure the app, provide my amazon password, create devices (3x Echo Dot v2 / 1x Echo Spot) and I can even play music through them so I must be using the correct server (US).
But always, after several minutes the connection is lost. I created 2 flows to receive a notification when a connect/disconnect happens. From that I can see that the connection never lasts more than 10-15 minutes.
As far as I know I have not configured any 2FA/MFA on my amazon account.
Any suggestions how to troubleshoot this problem?
Re,
Stanley.
hi
can you tell me how you do it. I also have Meross equipment
If you have the meross plugs/sockets, integrate that via the original meross skill in alexa. If you can turn the devices on/off with alexa and they will shown correctly in the alexa app than open your homey app. Open the Devices Tab and click on the plus in the right upper corner. Than add a new device with this Homey Alexa app. Go to the bottom, there you will find the device class âsmart plugâ. Click on it. If this Alexa App is correctly configured it will show you every meross plug you integrated in alexa. Add the plug you want. Thatâs it⌠Have fun and enjoy!
okay, thanks thatâs what I do, but he canât find anything and get me a time out. And take Alexaâs working perfectly
Hi, first of all Iâm super happy that I can let Homey speak something on my Alexas.
I have a flow where I take a variable an then let all my Alexas read the text out. Unfortunately that doesnât work well as only one Alexa is working properly, the other ones donât. This is random. I guess the app donât handle parallel text to speech processes. My question would be how I can read out a text to all Alexas and/or a group?
I did the same thing. I own 5 alexa devices and wanted them to blab certain events in the house hroughout the house. I did not get this to work stable. I do not think its a app limitation but a Alexa API limitation. I personally decided to create homey speaks routines in the Alexa app and let those events fire the routine. That works perfectly, almost in sync even.
But that depends on your use case, cause you can not send variable this way
@Jamie, just wanted to say that the integration has been working like a charm without any problems for weeks. All my devices are working and the TTS never stopped (EU server with MFA).
Great app, I used to start Echo to play music in the morning. Worked always well suddenly no reaction. After deletion of the APP and reinstall everything. Now it happend a second time, before homey made a restart (I have routine which let homey restart once a week). I think this was the rot cause. Any idea ?
Update: After a restart of the apps two times it works again.
Same here.
After serval days Alexa and Homey will lose connection again and again. In the app the corresponding dot has an exclamation mark which means it is not connected. A second one is still shown as connected with the same Account. A new connection with the Amazon account in the app has restored the connection. Also a soft reboot of Homey will restore the connection.
I.e. an account renewal or a Homey soft reboot leads to the same result that Homey and Alexa are connected again. If I now assume that a cookie is newly generated by TFA during the account renewal, how can this work without TFA input after a soft reboot? Probably only @Jamie can answer this question.
I donât get it how you have done this. You have a flow in Homey which triggers Simon says in Alexa app?
no i use the announce activity. it allows you to set a text and then select the devices it should announce to.
the others only speak from the activity set or associated device.
Great app @Jamie.
Apologies if this has already been asked but is it possible to display a picture on a Show (like the cast option on a Google hub)?
I would love to display the image captured by my doorbell on my Show devices so I can see who is at the door without having to ask Alexa to show the front door.
Sorry I donât know how to do that, is there a third party skill perhaps I can trigger and a routine to enable this?
It was a bit of a long shot to find out if you had access to something via the API.
I have the Ring skill in Alexa and it can make a announcement when someone is at the door but I have to ask Alexa to âshow the front doorâ to see the live stream. I canât find a way to automatically show the stream without asking.
With my Google hub, Homey can cast an image that has been captured by the Homey Ring app, so I was hoping there might be a similar action via Alexa. But it seems Amazon havenât implemented anything like that.
You have made a great app though and I love that I can get Homey to speak through AlexaâŚ
interesting, my show 5 devices do show the ring live stream automatically. ill see if i can find what my settings are
For me, my show 8 also automatic shows the frontdoor when my ring is pressed. No special settings that i am aware off
Ok, thanks for heads up, I will investigate further. At the moment mine just say âsomeone is at the doorâ. I have the original show, a spot, a show 5 and the new show 2 (Iâve not seen the show 8 so will look into that). And they all do the same.
