[App][Pro] Advanced Scheduler
I don’t know… I disable the flows. Tell me if at your place it works and I will activate the “flows” again
It woks here. Try one flow first just to make sure.
It’s working fine for me now. Last night at 2300 it kept locking and unlocking the door. Drove my wife nuts lol
It works for me. I disabled the app tot stop the continuous firung of triggers and enabled it at 01:00 hr. Since then no problems anymore.
I would presume that some time-variable in your app gets undefined because of the end of daylight saving time.
Regards,
Paul
I believe I have found the error. It is only a matter of finding a solution, that should not be so very hard. The hard part is testing, as this occurs once a year :frowning:
If someone knows how to set the time/date of a Homey manually, please let me know.
Maybe you should release the new version and we will test it next year. I like to live dangerously :sunglasses:
Regards,
Paul
Hi, I just tried your nice app but it seems I missed something…
I configured a simple schedule (your first example), but it’s impossible for me to find it in the when section of a flow. Can you help me?
Restarting the app after saving the schedule did the trick.
Hi @Kempo. Did you save the settings? That should make the list of schedules update in the flow editor. If that doesn’t work, please send a diagnostics report after creating a schedule and saving, and I will look into it. Also please send a backup of the raw settings.
@Peter_Kawa: restart after save should not be nessecary. Do you have to do that?
I understand. I also just installed the app, created a schedule, saved it, renamed it. No matter what, no schedule was to be selected as “when” card.
After restarting A.S. it became available & selectable.
I just made a second schedule, “test after restart”, and it’s available without app restart.
The 1-time restart seems like a sort of “first schedule init” or something?
Thanks a lot, it works also for me.
One restart and it’s ok
@Fredrik_Palsson yes I saved everything before
@Peter_Kawa @Kempo
This leads me to believe there is a bug when doing the first save-operation. I will investigate this and likely do an update.
My Homey kept rebooting yesterday and as such I started to do some cleanup and removed some apps and, for the time being, I disabled the Advanced Scheduler app.
After running without a reboot for nearly 24h I decided to enable the app again. All seemed well (since there wasn’t an ‘immediate’ reboot) but more than 12h later the Homey rebooted again.
I’m not entirely sure that the issue stems from the advanced scheduler app, but the “circumstantial evidence” points that way.
So… Any chance that the app is having some date related issues again?
In the meantime I’m going to try a different 5v 2a power supply. Apparently the one from Athom (at least from the early days) is one of the weakest links and a cause for sudden reboots.
I have not seen any issues myself, but I would love to find any bugs, of cause.
It is hard to track down bugs “in the blind”. Could you enable the app again, and if there are problems, please send a diagnostics report?
Thanks in advance!
After two rounds of clean-up (regarding apps and flows) + having replaced the power supply: I’ve not had any problems since.
So, I’d like to apoligize for sounding the alarm so blindly.
Given the fact that the Athom power supply is known for being low-quality and a cause for sudden reboots: I’m betting that this was indeed the cause of my problems.
Oh well, at least I got to clean-up my Homey a bit.
In any case: Happy new year! :wink:
Homey sent me a replacement power supply, but any time I contact them with a problem they always ask me to change it, preferably to one with higher potential output.
@Fredrik_Palsson may I ask you, if you plan to implement enabling/disabling schedules via flow? That might be nice enhancement mainly in case you need somehow to start given schedule, which is dependent on some other event… thank you
There is a plan to implement this. I have even made some very simple tests with this functionallity in mind. Hovever I would like to be honest and say it might take some time. There are many other things in life that are of higher priority.
If you are a developer, I would like to invite you to collaboarate on the project. Please let me know if this would be interesting.
The todo list and other things can be found here: Todo list · fpalsson/com.fp.advanced-scheduler Wiki · GitHub
If someone would like to maintain or improve this app, please let me know. I have limited time to do this at the moment.
