[App][Pro] Advanced Scheduler
Hi all.
I’ve been quite inactive lately. However, recently I fixed a bug that gave startup problems on the first initial installation when there was no settings written. It is amazing that all users likely experienced this as their first impression of the app and still there is almost 700 users :slight_smile:
I’m very grateful for everyones patience!
Definitely the application does not like the time change? last night the application had not taken the new time into account and started an hour later and this morning no store opened even an hour later…? On the other hand, there were no random triggers at midnight like during the last time change… I’m waiting tonight and tomorrow morning to see if everything is in order…
Also this timechange did not go flawless.
The scheduler has been off for 1 hour all day.
Any ideas how to fix this?
Will it be OK tomorrow? I’ll give restarting the app a go
@Fredrik_Palsson any way to fix this in the app?
That did not solve the issue
I am aware that the app missbehaves when there is daylight asving time changes. So far I have not had the time to resolve this, but I will give it a go sometime soon. I hope you can be patient with this issue. It should all work as expected tomorrow.
Coming here because I think there’s a link between today’s DST, the Advanced Scheduler app and the weird behaviour my Homey is showing as of since 23:00 today. Starting on 23:00 all my time-triggered-flows (through Advanced Scheduler) are triggering non-stop like crazy.
So in effect: Homey keeps on restarting (1st flow), the curtains opening up (2nd flow) and curtains closing (3rd flow). This is breaking the physical engine because it’s sending an opposite command every other second.
Only way for me to break this loop is to pull the plug on Homey. What is going on here?? How to fix it? Rebooting Homey doesn’t work…
Same thing tonight at 11.00 p.m. all devices related to Advanced Scheduler has gone crazy!!
Only one solution unplug Homey Pro. I will see tomorrow to reconnect it
The same problem. Since midnight it has been working fine.
I am very sorry this is causing problems for all of you. I have not had the time to solve this problem.
If anyone wants to help solve this the source code is publicly availiable at Github!
No apologies necessary Fredrik. We appreciate the effort that youbhave made to create this very usefull app. It is crucial to me!.
Kind regards,
Paul
It is indeed only the day of the daylight change itself…
Day after everything works fine again.
Hope you find the time somewhere before the next daytime saving switch…
The app is really usefull!
Hi @Fredrik_Palsson ,
I’m surprised nobody yet asked you, but do you please plan to upgrade for SDK3? :pray:
Thanks for the suggestion, but there is too litte time to spare to upgrade to SDK3. You are most welcome to contribute if you know a little java. The code is available at Github.
Hi @Fredrik_Palsson , nope, I wish I would know :frowning:
Hopefully someone will take over then. Thank you.
Hello, will “advanced scheduler” still work on January 1st? I didn’t quite understand but homey is going to SDK 3 on January 1st? As I will not be at home on January 1 and 2 and 3, do I have to stop all my flows managed by “advanced scheduler” before leaving home? In advance Thanks for a quick reply
Your homey has been on SDKv3 for 2 year now.
So no, any already installed apps will not stop working.
From January 1st apps on SDKv2 will just not be installable from the app store, but they will not stop working on your Homey.
OK and thank you!!
@Arie_J_Godschalk I know your portfolio is pretty full already, however this might be your cup of tea maybe ? Just asking, as this app is quite unique in terms of functionality…
I posted a request for a dev at the Slack developers channel, fingers crossed.
