[APP][Pro] 50five - Smart charging at home for you electric vehicle
9fad0868-8c56-4421-8286-18ab3f2f2391
thanks,
Tim
Very weird log. Not sure what to make from it.
Can you send me a screenshot of the 50five portal with the session log (expanded with details)?
Please do so while your car is charging for more than 10 minutes. Then also send me a new log.
It is very strange that your usage is working but the energy value is not. There is a relation between them, so that doesnt make any sense.
Basicly the meter consumed current (active session usage) is the value I add to the Energy meter. So how are those updated but the current energy + session usage = 0?
In your screenshot the current session usage is 14Kw. so even if Energy was 0 should at least now be 0+14 = 14.
Doenst make any sens :frowning:
This is the 50five portal of the active session:
This is the log:
8decdf49-45d5-4627-ae79-797bad040743
Big thanks!
Tim
Can you try this test version?
50five | Homey
Bingo!
Thank you very much for your help!
Tim
Hello, I’m a very satisfied user of this fantastic app, which I believe is also well-maintained. Thanks! However, there’s one flow chart I don’t quite understand. It starts a charging session with [number] kWh. I’ve only entered 15, but does that mean it automatically stops after 15 kWh has been charged? Or should it have been kW? I can’t imagine this station can adjust the power.
That’s a deprecated card indeed, it existed to allow the Homey to estimate with what speed you expect to be charging for the entry dash. But with 50five we can finally retrieve this info so it’s no longer used.
Ah okay, haha. This old flow card is the only way to start a charging session for business reimbursement, so despite its age, I hope it stays. Perhaps the kWh section can be removed in an update, as it no longer serves any purpose.
eh, Since this morning, I’ve been getting the message five times an hour that my car is starting to charge, and shortly after that it’s fully charged. All these pings were driving me crazy, so I completely disconnected the power from the charging station, but I’m still getting the message! Am I the only one? And is this related to 50five? Or to Homey?
What is sending the notification? Your cars app or Homey?
I can’t change params without breaking people’s flows, that’s why deprecating is the best option. Add a new one without the params, deprecated this one. All existing flows remain operational but when you create the action new it would be gone. I’ll put it on my todo
It was Homey that sent it, but I saw on the 50five portal that the charging station there also constantly changed color even though nothing was connected. I suspect my charging station is about to need replacing :frowning: However, after I turned off the power circuit, left it off for an hour, and then turned it back on, the problem was solved. I haven’t had any more false alarms today.
Sorry, probably a really stupid question, but which card can I choose now? If I leave the capacity empty, I can’t save the flow; I get an invalid arguments message. Hopefully, the new card will become available first before the old one is deleted.
Just enter anything you want, it just not used in the code.
It used to work fine for logging, then stopped on Oct 13th 2025 after which I used repair. It then logged once on that day and never since. I can’t repair it now because it won’t accept my credentials (which I checked several times, I logged in to the website and the app with those same credentials). Diagnostics: 5fb6ff2f-b206-4cb7-bf8c-dbad059a15c5
Any ideas?
Thanks,
Paul.
What version are you on? Still shell?
50five
v4.1.12
Hi! First time user of this app, looks promising!
Im trying to login but get ‘login validation failed, check your credentials’.
I’ve searched this forum and found two URL’s:
https://50five-sbelux.evc-net.com/ and https://50five-snl.evc-net.com
I have an other URL on which my account is registrated: https://50five.evc-net.com/
(so without ‘-sbelux’ or ‘-snl’)
I’ve tried all three URLs, unfornunally all of them dont work. Anyone had a suggestion for me?
Make sure you don’t use the last /
And use the one you actually use to login to the portal, and keep an eye out for redirect, so when the portal gives you the login box, the domain you are on at that moment.
And what’s is the domain you use?
