Ok, Thanks, so for me is this not the solution. My trigger for alarm creation is the google calendar, like in my flow with card “event begins” in icalCalendar app.
this is funny, I wouldn’t understand, but then you post a new version to V1.6.1, with new flowcard.
I’ll check it out in the next few days, but this seems like what I’m looking for, thanks! ![]()
Well, that time I offered you a concept of how it could work, and now to show clearly had to implement ![]()
I see the app isn’t maintained anymore, but is it still possible to add some wake-up lights? When i try to add devices, i got the message that homey can’t find anything.
Why would you think that? This application is fully mainteined. If you have a problem with device connection, create a bug report here, we’ll try to sort it out. There you can also describe the functionality you are missing.
Hello Vladyslav,
I readed this reply so i thought the app isn’t maintained anymore:
Sorry for not actively maintaining the app. Life happened, and time got away from me. Right now, I’m not in a position to work on this project, and I’m not sure when I’ll have the time again.
I have the two sleepmappers added in this app ![]()
Now i struggle a little bit with the alarms, but that’s a user issui ![]()
That was said about a different app and by a different developer ![]()
I see, sorry about that ![]()
Could you help me with the settings?
I have a problem with the philips wake-up lights. (i have one, and my girlfriend).
When my girlfriend adds a new alarm in the philips sleepmapper app, the alarm appears on her wake-up light, but also in my own light. How is this possible and is there a solution to stop this?
I don’t know if it’s a problem of the sleepmapper or from your app, because in both apps the alarms appears.
This happens because alarms from Homey are set globally when added, as you are most likely using one Homey Pro hub.
To set alarms for each device separately, in my app you need to use the Alarms Syncronisation Name setting from the Advanced Settings of the device. You can set the name My Philips Alarm for yourself and My girlfrend Philips Alarm for her. This is just an example, you can use any name you want. When you create alarms, they will still be displayed globally, i.e. in the Homey app you will see both your alarm and the girl’s alarm, but in Somneo they will be created for each device separately.
I think you mean the alarms are added trough a homey flow or in the app right? But that’s not the case in my situation. New alarms are added in the philips sleepmapper app. And then they go off on both devices.
So do i understand that’s also the problem? We do not make alarm anymore in the philips app, but in the homey portal for let it working the right way?
You don’t need to use philips sleepmapper, you can create alarms through Homey. For more information, see Advanced Settings in the Philips Smart Devices app for Somneo.
Hello, sorry that i didn’t respond anymore. I didn’t have the time to test things out.
The devices are now correctly intergrated in the homey app ![]()
Is it possible to share a screenshot how i make a new alarm in homey for the wakeup light?
I have read the instructions in the advanced settings, but i can’t find where i need to put in the alarms synchronisation name.
My flow needs to be very simple like this, with no automatic things. But in this format i couldn’t get it to create it in the wakeup light.
