[App][Pro] Philips sleepmapper app, wake up light
Hi all,
Just a post to announce my new Philips Sleepmapper app.
The app adds support for the Philips wakeup light (Somneo). It exposes the sensors from the alarm to Homey and enables main light support.
Known issues:
  • My wakeup lights (two of them) have trouble staying connected to my Wifi, after a couple of days they become unreachable. So the mobile app suffers from this, but the Homey app also, obviously. Let me know if this is an issue with you also.
Philips Sleepmapper App for Homey | Homey
Hi Koah,
Thanks for your efforts in creating this app! I’d like to adopt our Philips wakeup light (controllable through the SleepMapper app) but unfortunately, after the pairing session, the device shows a red exclamation mark in Homey along with the dreaded “Device unavailable” error.
I tried re-pairing the device, restarting the SleepMapper app (in Homey) etc. The wifi connection to the device is stable and I can control the light perfectly through the smartphone app. Is there anything I can do to assist you with debugging this?
I see i have the same issue now work mine. I’ll give it a debug attempt sometime soon
I just published a new version. The issue seems to be that I loose the Ip address when it changes. I fixed the discovery process so it now finds them again. But… you need to re-add the devices. Sorry about that. I did not store the unique id of the light and thats why the discovery could not be updated to the right device.
So re-add, and it should remain working from this point on
That’s great, thanks for the quick fix! Re-adding it was no problem so no worries.
Hello @Kaoh, there at two models of Somneo … which one is supported by your app? Thanks!
I can’t test them, but I believe both
Hi Kaoh,
Thanks for making the app!
I wonder if it is possible to start a sunset with a flow? When I go to my device I can start a sunset, but I see no such flow card.
I have button next to my bed which turns off all other lights and so on and it would be nice if I could add that it starts the sunset for x minutes.
I admit i did not spend much time on flow support. Ill put it on my todo
Hi Kaoh,
Many thanks for your work and for your application.
But I have some issues with my Philips Sleepmapper HF3670/60 in app.
Flow cards like When Activated/Deactivated, or When nightlight activated doesn’t do anythink. For example I clicked on Sunset button on my device and flow card not triggered.
Do you know what the problem, in my device or in youe app? Thanks :slight_smile:
P.S If you share your github or gitlab or anything else I can help you with maintaining of application, I am also developer :slight_smile:
I have not tested that part very well, so could be my app.
kaohlive/com.philips.somneo (github.com)
Same here. All functions seem to work as intended except for the sunset function. Looking at the device log it seems it always deactivates after sunset is turned on. Maybe that is the issue?
Hi thank you for the app.
Any news on the alarm support?
Since the lights are unstable in their own wifi connection at my house, my use cases for that effort became less.
They are a bit more stable now so i might pick this up again. But life is keeping me very busy as is the govee app development.
Thanks for bringing it back in view.
Np, good luck and hope you can find the solution and the time for it.
Hi, thanks for this app, I currently have the Philips Somneo HF3672/01 (Latest model) and would like to use the Sunset mode and alarm. I have already tried different settings but currently not successful. What am I doing wrong.
There is a new app in the making by another dev, he is a bit further on these type of features, like alarms and sleepmode and I think also these features.
It is still in beta but I am testing these features and while there are still bugs I think he is on par with what my app could.
Philips Smart Devices App for Homey | Homey
So for now I am freezing dev on this app and see how his progress is. Would save me time :slight_smile:
Thanks, I will install and test this app
I recently changed my wifi, so i had to reset the wake-up lights. Now i would like to get them back into the homey pro app, but the homey can’t find any devices. Any solutions?
They should rediscover themselves, normally there is no need to re-add them.
