[APP][Pro] Magic Home LED
@PV2134
So I had a chat with @Chris_nl and he told me that you can change the type of your ledstrip via the Magic Home app.
For the AK001-ZJ200 I would suggest to set it to RGB / W (This means: RGB OR WW). You can do that as shown belown. (long press on the device)
magic-home-setting.
In the Homey app I made a toggle to set it to RGB+W. So you can control both LEDS at the same time.
But this will be default disabled. (check-out the latest test app below)
Brightness for RGB goes via the DIM tab.
Brightness for WW is the WW slider / color wheel. As it is a temperature. Which will go from off to warm. As shown in the flow earlier (Shared Flow | Homey).
