Thanks. I think you are right. There is only one parameter (20) which is used to define the type of switch to both S1 and S2. Not individual settings.
Then maybe the fibaro app should only allow for one setting on S1.
Since my update I had to remove and add all the devices manually. I had one fibaro switch only for measuring. Is it still possible to disable toggling the switch from the Fibaro single switch 2? I can’t find it anymore in 2.0.
Can we expect an update that fixes this anytime soon??
I think it is kind of ridiculous to have things as they are now, and not roll back to a version where everything just worked.
Or is re-including the devices the new way forward…???
Please tell me that is not the case.
All the options are still here. Long press on the switch (device) then settings (up right corner) then advanced settings.
I think only one or two type of fibaro devices had issues. I’ve lost my mind initially as I thought I will have to digg the switch for the reset button. At the end I only had to re-add one device.
All in all, everything is working now for me. I’ve disabled the auto update and will again update after a 1-2 months for things to settle. V2.0 is a completely new device. We just needs to live trough this couple of months and we are back in the calm waters.
I see this option for the fibaro wall plug indeed, but not for the Single Switch 2 anymore.
It looks like that the double switch 2 (S2) only works via a flow or “groups” as suggested. The tile in the Homey app is broken.
Exactly, I have the same experience, same applies for the double relay by the way.
@Bram are you with us?
I want to use a fibaro double switch 2 behind a mechanical switch in my kitchen that is now used to switch a power outlet in my garden. I have no need to switch this power outlet, so i want to provide constant current to it by bypassing the mechnical switch. That leaves my mechanical switch unused, but i now want to use this to switch a hue lightstrip in the kitchen that is powered from somewhere else.
So: can i do this with a fibaro double switch 2? Can i make a flow with a double switch 2, without it having a direct load attacted to it? Will it switch in homey?
@ditisstephan yes, this is possible, i use this myself 4 times, just make sure you don’t use the dimmer 2, as that does need an output attached.
The Tamper Alarm is constantly on with Fibaro Motion Sensor FGMS-001 after update to 2.0. and temperature and luminance updates very seldom ( like after 10 - 12 hours). Device settings are unchanged.
I dont know if that is a hardware or software problem, but something is wrong. Any idea how to solve this issue?
i have the same problem with the tamper alarm for the fibaro motion sensor, so i think its not your hardware.
Yeah Athom needs to finally step up and fix the app…
I wonder what’s going on with the app/firmware…
I installed a new Double Switch 2 yesterday, everything is working just fine (at first sight).
Double Switch 2 is working normally after app upgrade. I personally just removed it and paired it again. I think maybe it would work even without re-pairing. You have different experience?
The new firmware rc2 fixed my problem with the double switch now! firmware.athom.com
I still can’t use the tile in the Homey app. Flows are working but no manual switching.
Try restarting and disable/enable Fibaro app. Then ptp if it won‘t work.
The new release fibaro app doesn’t fix the double switch S2 tile.
2.0.1rc fixed the Fibaro Dial switch error for me.
