[APP] Fibaro - Your home is your castle (by Athom)
Thanks for emoji recommendation (struggled to find an appropriate one for fans).
Did anyone set up an official feature request for custom icons? using the form ?: Feature request for Homey
:dash: or :wind_face: :wink:
More infos about the “new” sort of feature request you can find here:
I just got a wall plug (UK) and it’s been detected as a “Basic Z-Wave Device” and doesn’t seem to do anything…
The wall plugs say they are supported - what gives?
Here de same. Today a brand new wall plug but homey didn’t see him. Delete an old working plug and try to connect him again but no way.
Well, that means it is not being recognized by the app. It tries to recognize based on ID’s provided by the plug. And if they haven’t been added to the app, they are not being recognized. So my advice would be to open a support ticket with Athom and provide them with the correct id’s.
Hi, i use several fibaro motion sensors and have 5.0rc62 and fibaro version 3.0.4 installed . Since rc62 i have the problem that if “motion detection pulse counter” set to 1 the motion alarm i s more or less always active, after cancelation time it goes shortly off but after one second its activated again. Before 62 it wasn t a problem. Do someone have also this problem? (in meantime i set it two 2 pulse)
I have 4 of them and have noticed no problems. But all of them are set to 2 pulse. Homey rc.62 / Fibaro v3.0.4
In the meantime rc.63 was released. Hopefully it was a bug in rc.62.
Hi, i already installed rc63 but still the same problem.
Have you already tried to restart the Fibaro App or/and Homey (PTP)?
Hi yes, also did a reset of the zwave network and added the motion sensor again but still the same.
I have no other idea, sorry. Maybe someone else?
I guess you have to contact Athom.
thanks, yes i will do. it s working fine with 2 pulse but there is a liitle bit a delay if i enter a room and the lights turn on. It s not a big issue but before it was much better.
Hello guys,
I have problem with my new Fibaro Smart Implant. I reported it here:
Could you please take a look at my post in that thread?
Thank you,
Frank.
I’m confused about where I can find the lastest source code, anyone who knows?
Master branch app.json seems to at version 3.0.0 with and an very, very outdated README.md
In the app store there’s a 3.0.6 out (only a few days ago).
Isn’t GitHub used anymore? If not, why is that?
The reason I’m asking is that I modify the source code so all my Fibaro devices doesn’t get added securely.
Github is still used, but they decided to publish updates into a private fork of the app.
Why you’ll have to ask Athom.
Adding it insecure can be done by adding everything as a Walli. It will still add as the device is really is, but unsecure. If that doesn’t work, I doubt changing the code will.
Awesome, thanks for the tip!
Anyone who knows the easiest way “switch back” to the app store version of app? I’m currently running the app in development mode (“homey app install”). I want to switch back without loosing all devices and their configuration.
Changing the code works well, but it has to be done for every device template. My Z-Wave network is so much more responsive since this change.
