[APP] ELKO Smart - Smart, right?
Had to go into the ceiling.
Moved pucks, dimmers, free locate, ikea, hue, LG tvs. All good.
Is anyone else using ELKO smart pucks with their homey bridge?
In the past we’ve used the ELKO hub, but ELKO doesn’t seem to allow both a connection to its own system and also homey bridge. Therefore we ended up only using a connection to homey now.
However the range of the dimming is not the same as it is when using the ELKO system. 1% light in homey bridge is more similar to 15% when using the ELKO system. And we would like to be able to dim the light to less brightness.
Has anyone else experienced this?
Also if anyone has a good fix for how to use the ELKO light switch when using homey I would much appreciate some input . Its functionality is very limited compared to when using the ELKO hub.
I have the same experience. The lights cannot be dimmed all the way down to 1%. I have tried to set the limits as low as possible without them turning off completely. Changing the mode from automatic to Rl-led doesn’t help either, as the unit stop Working randomly. You have to remove the fuse and the power to reset them. Factory reset does not help. We have generally had a lot of trouble with the electric switch regarding noise and dimming. I know Elko is Working on this, and if elko hub works fine to get dimmers lower down, homey must try to send the same instructions over the zigbee channel.
Yes with the elko hub all lights can dim down to zero light. (I have also tried changing from automatic without success.) Also experienced some issues with lights being constantly off and having to take the fuse in order to get the light back on. These kind of issues I have never experienced when using the exact same pucks and lights with the Elko Gateway. So its not the product itself.
I have been in contact with the product manager at Elko about this not that long ago. The information he gave was that they are using an external company to develop the homey app, and that as a part of the service we should be able to contact the app developer directly. However i have tried, and I havent received any response.
I am unable to connect the Elko Smart 4-button switch to my Homey Pro. Homey tells me to hit the #1 button tree times for inclusion. Nothing happens. No light, no action in Homey. Should I instead do something with the A button perhaps?
Read a lot of contradicting comments about this dimmer , Elko smartdim vri multiwire rs hvit.
I have 4 of it in my home and wondering if anyone could confirm if itsworking ok, all lights off on, dim on of via automation or through the app, with the latest homey pro.
I’ve gotten a good offer on a used homey pro.
I have many Elko GLED 316 in my house and they are all connected and work well with Homey. Recently I installed two more GLED 316 dimmers, and I am not able to include them in Homey. I see no reaction in Homey when I try to include them. I have not reached the limit of ~100 Zigbee devices, and I have even tried to move Homey close to the dimmers, but no change. Any tips would be appreciated!
I just installed new Elko Smart Wi-Fi thermostats which I would like to integrate into my Homey system. I already have some Elko Super (Wi-Fi) Thermostats integrated. I integrated these directly into the Homey system without the need for an Elko hub. However, I am not able to install the Smart Thermostats through the Elko Homey app. Nothing happens when I try to connect. Does anyone know whether the Elko Homey app only supports the Zigbee thermostats? And if so whether I will be able to integrate the Smart Wi-Fi thermostats into my Homey system if I get an Elko hub?
I’m planning a new smart house with Elko smart and Homey pro. Question regarding SmartDim functions. I have experience from using Heatit Z-dim where you, in addition to on/off+dim, can run various Scenes defined by number of clicks.
Is same functionality possible with Elko smart? Or do you need to combine SmartDim with wall controller to run Scenes?
Old post now, but yes, these work well. We have many, installed this summer.
I think only Zigbee is supported. How are your existing WiFi thermostats integrated?
What is the purpose of this functionality? Flows in Homey are not device specific, they are all made the same way, but different devices have different triggers, conditions and actions for use in the flows.
My thermostat in the bathroom has stopped communicating with Homey after the rush of recent updates on my Homey.
Does it need repairing? It does not help to restart Homey though.
Hi, I have some general questions :slight_smile: I have moved house and gotten up some Elko hardware which works fine in the Elko app. Have started to get homey up and running in the new house but I haven’t figured out the Elko part yet.
Can I not pair all pucks, smartdim vri and thermostats in both the elko app and Homey?
Tried putting the smartdim vri in pairing mode but it goes to blinking green instead of amber, could it be since it is already paired with the elko app?
Must i reset every switch to add them in homey, and if so can I add them back with the Elko hub later?
Zigbee components can only be connected to one controller. You need to choose either Elko hub or Homey.
Always something to learn, abit late :slight_smile: I assumed it would work pretty much like Philips Hue.
Anyway I read up more on it, the Elko smart hub was recently discontinued and will be replaced by a Schneider Wiser hub with matter support this fall (real soon I hope). Hopefully I can get everything as i hoped for then.
Edit: I will try to add the Elko gear to Hue when i think of it, maybe that could be a solution :slight_smile:
I have 5 Elko Smart ZB Thermostats that I am unable to pair with the Homey Pro. I’ve tried:
  • soft-reset
  • factory reset
  • re/uninstalling the Elko app
  • restarting the Homey
  • firmware-upgrading the Homey
Any others experiencing this?
If they’re battery powered devices: when the device has entered the pair mode, you’ll need to push the pair button every other second until the pairing process succeeded.
This is needed to prevent the device entering “sleep mode” (invented to extend battery life).
Pls keep in mind 2.4GHz wifi signals can disrupt zigbee signals when you didn’t selected the best possible channels.
This and many other need-to-knows:
No battery. It’s mains voltage. I have been trying channel 1, 6 and 11 in the 2.4GHz range. I changed the homey power adapter and can pair a few now, but they become unresponsive after between 10 minutes and several hours. (“Timeout after 10s in the Homey GUI”) when trying to change temperature or other features.
I think it’s best to report to Drenso, the app maintainer. Contact info can be found in post 1 of this topic.
