[APP][Cloud & Pro] SwitchBot (Release 2.0.96, Test 2.0.104)
Hi Adrian, on test version 2.0.103 my Blind Tilt (via Hub Mini, cloud) is polled every 15 seconds even when idle (~240 API calls/hour), although the webhook is registered fine (queryWebhook returns the Athom URL). Hub 2 and the curtains are not polled like that. Is there a way to stop or slow down polling for the Blind Tilt?
Yes—this was an inconsistency in the Blind Tilt driver. Its webhook contains the position and battery information that Homey needs, so continuous 15-second polling is unnecessary. I’ve changed it to fetch once after startup and then rely on webhooks. Older paired devices without type metadata will retain polling as a fallback.
Ok, but it still logs it. I just sent you the log, I have 3200+ api calls with no devices connected via BLE. I have 6 devices connected via a Hub mini and a hub 2.
The fix is in 2.0.104, and your log is from 2.0.103, so I think there was a delay in the update appearaing.
Ah, gotcha. It hadn’t updated, I forced a manual update and now there’s sweet silence :slight_smile: Thank you for the quick fix.
