Installed your app 4.0.1. Deleted token and used “get token”. Only got notification .
When i try to attach a device with the somfy app i get: "Hostname/IP does not match certificate’s altnames: Host: gateway--‐.local. is not cert’s CN: ...local
That would explain why you can’t enable the developer mode as it was only added to the box firmware this year. You raise a support question with Somfy to ask if it can be updated.
I have published a new test version that sets up an alternative URL to match the certificate.
It seems the certificate in my box has several ALT names, so it will work with the real URL and the URL that you have. Fingers crossed this will work with all the boxes.
If you open Homey Developer Tools and then select the Somfy Tahoma and Connexoon app, then the Information log tab and enable the log (blue tick) you should see the polling. If you have entries like:
"time": "2022-07-11T20:02:40.685Z",
"elapsed": 3.018,
"source": "syncLoop",
"data": "Logged in = true, Local = true, Old Sync State = false, Next cloud sync in 21s"
where Local - true, then it is polling the hub directly.
Not all devices are supported directly via the hub. If you go to the Device tab and click on Get Devices, the list will show all the device connected locally and via the cloud.
The list is a large JSON object so can be difficult to read. I normally copy the contents and paste it in to a JSON viewer.
@Adrian_Rockall when I buy the connectivity box can i use it for my rts blinds then ?
And can I add my blinds and then eventually use your app? also the function to tilt the blinds? And could this possibly also be possible with speech (google aasistent)?
First of all big thanks for the app !
I just bought the Connectivity Kit
successfully add my Roller shutter with quiet mode in Tahoma App
successfully connected my Tahoma credential in your app in Homey
checked “Get log” in App setting > Device log
but unfortunately app cannot find my device when I want to add it. I tried Roller shutter with quiet mode (IO) and Roller shutter (io), but getting message, cannot find your device…
I sent the log via the app few minutes app
Thanks in advance for the help
