[APP][Cloud & Pro] Somfy Tahoma & Connexoon (v4.0.124, test v4.0.152)
Logic ?
Go to the device and use this card :
I was referring to the logic card ‘positie is kleiner dan’.
Ok, sorry, misunderstood. I also use this :
afbeelding
Okay so instead of 90% its 0,9?
Athom have always used values between 0 and 1 to represent the position internally and convert to % for display. As variables are low level they don’t get converted, so you see the 0 to 1 to two decimal places.
And if 0,9 is not working try 0.9, so with a point instead of a comma.
Yes, ‘set position’ is a slider, as a logic to request the position it’s in decimals
Edit: home always use a dot as decimal separator
I can’t see my roller shutters in this app. I can control them from the Tahoma app, but when I try to add them to Homey, it logs in to my Tahoma account buy it says “No new devices have been found”. I’ve sent information log and device log 1254257483
Try the “Velux roller shutter(io)” driver as that supports your motors.
Thank you. It works. FYI in Tahoma I have registered them as Shutter io.
The app only sees the motor type and different manufacturers use different motors for the same job.
Hello everyone,
Since the last update yesterday (Somfy TaHoma and Connexoon were automatically updated to version 4.0.122), my roller shutters no longer work properly with the Homey app. Some roller shutters move in discreet mode, MA position stop at 14% vs MY position in Somfy app (26%), etc. They work correctly with the Somfy app.
Am I the only one having this problem?
Homey Pro (Early 2023) v12.7.0, with Tohoma switch v2.1 and IO RS100 roller shutter.
Thanks for your help.
Since a few days, I cannot connect to my TaHoma switch anymore. The devices don’t show any reaction and when I try to login (through ‘repair’) I get the message ‘Far Too many simple login attempts (blocked for 24 hours). How can I get into contact with the developers (RockSoft Solutions) about this? I can access my Somfy stuff with the Tahoma switch without any problem.
I published the latest version on Sunday, so it rolled out to Homey’s Monday morning. That caused a lot of Homey’s to login at the same time and Somfy saw that as an attack and blocked the Homey servers IP addresses.
The app will pause logging in for 24 hours and then back off login attempts for a random amount of time to stagger further log in attempts. Hopefully, this will allow the system to recover. Please don’t stop and restart the app as it looses track of the timeout and causes the Somfy lockout to reset which will just prolong the issue.
This only affects Homey cloud as there are multiple Homey’s running on each server/IP address.
I hope the Homey cloud users can re-use the somfy application again soon
The app update is three days ago, but still all my screens are not working automatically via Homey. Waiting more than 24 hours without peforming a repair action doesn’t work sofar. Do you have any idea how long we will have to wait?
Unfortunately I have no idea. I don’t have access to any more information than users do.
I will however ensure I don’t update the app again and only publish test versions so users will have to manually update.
The problem is worse now as there are so many users on the Homey cloud.
Sounds as a better plan.
What is the easiest way to know when you have published a new test version? At the bottom of the Somfy app page on the Homey website?
Yes, just follow the “View changelog” link on the app page at the app store, to see the most recent changelogs.
Unfortunately there’s no hard-link you can bookmark.
Just to be sure: will the Somfy app in Homey Premium start working again by itself, or do I have to do something at a propriate moment? (it is still not working)
