I have the same issue. I can arm and disarm the system, I can turn the cams on and off, but I am not getting a motion trigger. That is really unfortunate. I wanted to use the HEIMDALL plugin but w/o the motion trigger is does not work.
Hello DennisO,
What is not working on the Blink Mini camera? The app should show the camera as a device.
Maybe you can test our test application?
Thanks! With the test application I can now see the option to add the blink mini camera and I have been able to successfully configure it as a new device. When I try to view the snapshot I get the error message “invalid_image_buffer”.
to me also on older blink cameras…invalid_image_buffer.
today Blink App updated to 1.0.5
Blink Mini Screenshot is Back!!!
other cameras (XT2 and Indoor Cameras) are still giving INVALID_IMAGE_BUFFER
Thanks.
Same BUFFER error here.
And motion detection still not working.
same here
Will this affect the connection to blink cameras?
No, the app will work after that! On this moment you getting an code by e-mail, then you get a code by sms!
Fixed in the last version!
Am I correct that I don’t see the new version in the AppStore yet (also not under test)
Latest I’m seeing is the .5
Latest version is 1.0.5, if it still doesn’t work please create an issue on github.
Done and included diag report but I don’t think that will bring much. As you can see above it seems most users have this on .5
If you want access to cams pm me for the access codes if you need
The version 1.0.5 is not able to login. It gives only error message “invalid credentials”.
There us no 2FA screen coming up.
Login in blink app is ok with 2FA code via SMS.
Is this a known problem?
Same problem here. Can not log in and app is unable to control my blink XT2 cams anymore.
By the way: there are only indoor and mini cams to add as new devices.
Same problem here
Confirmed, also having the invalid credentials message. How can I help?
can´t add a Blink mini, using this app for the first time today. When searching for the cam, I always get the error message „cannot read property ‚name‘ of undefined“.
An other user got the same issue: Cannot add blink camera
Is this related to the login problem? I mean, I had no working Blink before, so perhaps even linking a Blink mini to homey won´t be possible?
Any updates for the auth error?
Is the app still in development or is it abandoned?
I was looking for additional cameras, but not without the integration
