I also have some issues with my xiaomu buttons/switches (called Wireless Switch in app). Not able to start flows.
Also, I have a couple of Xiaomi Human Body Sensors (Motion). One of them acts a bit strange in V2.0. It was triggered 17 hours ago and has not been disabled since, dispite that it is set to be disabled after 300 seconds (standard). I am not sure if this can be done manually.
Apart from that, I really appreciate your effort to keep this app updated Ted! Cred to you!
I assume the app builder needs to adjust some code to have the buttons work with 2.0. Can take some time as this probable needs to be done next to his/her day job.
I had a fresh one and had it successful pair just a minute ago. Had to wait some minutes before the pairing process was successful and had to push the pair button several times. But in the end it is paired.
And i am talking about pairing a vibration sensor with 1.5.13.
Edit; made a flow sending a push msg to my phone when motion is detected and flow works fine
Due to the signals above I am not updating yet. Almost all my lamps are “behind” one aqara wireless button. If they don’t work my wife will … (Fill in for yourself). So anyone who can share the news that the buttons do work with 2.0 can make happy and I will update.
Yes!!!
I succeeded.
Workflow:
pushing button for 5 secs. blue led light up, flashing 2 times, release button. After e few seconds 3 times flashing blue LED. -> tekst: “Apparaat toegevoegd”
AFter that pushing the button every 2 seconds for about 20 times (As long as pairing is happening) -> pairing succeeded
Hello Tedtolboom, when i select within a new flow een scene is geactiveerd or een knop is ingedrukt, both are not working with the aqara wireless switch. Can it be something else?
@Gerrit_Ekelmans you did select the right option in the “a scene has been activated” card?
Only thing I can think of is that for some reason the connection between device and Homey is disrupted.
What does the node overview at https://developer.athom.com/tools/zigbee show?
