Any experiences with LUUMR devices?
I’m looking for LED lamp replacements, and stumbled upon the non documented LUUMR lamps.
Eg https://www.lampenlicht.nl/smart-gx53-dimbare-led-lamp-9w-806lm-2700k-6500k#details_anchor and Lichtbron 9W Zigbee/Tuya/Philips Hue RGBW E27 - Luumr - Koop online
Anyone has any experiences with them? Anyone lucky using the Homey to control them?
Any luck with those? I found a g9 fitting variant from LUUMR I would like to add it to the hue bridge or alternatively direct to Homey. Not much to find about those.
LUUMR is apparently based on Tuya (Wat is de Luumr app? | Lampenlicht). In the description on this (Dutch) page is says nothing about needing a hub. Only the LUMMR app would be sufficient. That leads me to the conclusion that it can only be Wifi controlled. Maybe try with the Homey Tuya app?
Just got Luumr G9 bulbs. No problem in connecting to Homey pro. Connecting was done under generic Zigbee category. I did not need an special app or bridge of any kind. Lamp is working perfectly.
I used the Zigbee version of the G9 bulb. Also an WIFI variant is available but did not use this one.
