Amending a mood
I have changed some lights used by a mood and now want to incorporate the new hue lights, but are struggling to update the mood for the new lights in the scene.
I set the mood first, which turns on the existing with lights with the new lights not included, I then set the new lights to the desired colour and level, using the hue app, then select edit mood on my homey iPad app, check the lights are as desired and then select the tick in the top right hand corner to accept the new mood. However it is doing something else; one of the new lights was incorporated fine, one wasn’t and one existing light which hadn’t been changed ended up excluded. Changing a different mode had similar results. I have tried, instead of using the hue app to turn the lights on, in the edit mood function to no avail. Is there a way to edit a mode?
