Am I the only one not being able to use the flows on the web anymore?
I’m not able to add any device action ar really anything to a flow anymore on the web app.
When I select something, the device is shown in the UI until I press the left button and then it goes away. I the console I see:
Unexpected value calc(100% - 2px) parsing height attribute. react-dom.production.min.js:23:235
Here is a short video: HomeyIssue
So basicallly my home is completely useless right now and I don’t know what to do. I tried 3 different browsers, rebooted the PC and still the same.
Does clearing the browser cache have an effect?
Nope. Tried that. also tried firefox, Edge and Chrome. :frowning:
Antivirus/proxy/something hijacking your browser connections and “improving” them?
I’m experiencing exactly the same phenomenon, but not all the time, but in most cases :woozy_face:
Using local access, or the web app makes no difference.
Because it selects other flow cards when you click on certain positions on the canvas, I’m suspecting the flow card selector stays active for a while, but now as pop-under instead of pop-up.
  • Workaround (at least for me):
    After selecting a flow card, waiting for several seconds (20 or 30, just test for yourself) makes it possible to continue.
Peter_Kawa, that seems to do the trick. robertklem, not sure if that is the case as it’s on all browsers I tested. But might need to test on another machine to confirm.
Just a little update. It works fine on another machine. So it must be a plugin/extension I have on one of the PC’s which does not work with Homey. Tx for the hints.
It comes and goes. I’ve tried so many different things. One major discovery: it doesn’t seem to affect editing advanced flows @ my Pro 2019, only @ Pro 2026 (either connected locally or per my.homey.app).
