Hi everyone,
I just got started with homey and I have my first probably noob question.
I have a Daikin ac connected via ONECTA and central heating controllled via evohome. I want to use my ac for heating but it’s hanging above a radiator so it gets a wrong temp readout if that was used.
Is it possible to make that I can use something like a Aquara temp sensor as thermostat of the Daikin ac so that it has a real temperature readout instead of the internal one that has a wrong temperature.
I know it is as probably a real starter question but I really appreciate the help since I am real beginner.
Greets Sjoerd
Something like this (from an existing example, leave the floorheating out and replace towel heater with your AC)
It’s more that I want to use an external sensor as a temperature readout where the Daikin is listening to.
I can see i can set a temprature target. but nowhere which sensor to look at.
And since i also have a temprature readout from my honeywell thermostat i was hoping that i can use that one so that the ac unit has a good reference point since the internal sensor is completely @ the wrong place.
or is this something where i need to use advanced flows?
Yes, the trigger in my example are separate Aqara temperature sensors.
But you should be able to use Honeywell room temperature as trigger.
I made a standard flow example for you, only I have a tado thermostat instead.
It is possible with this Honeywell lyric app https://homey.app/a/com.honeywell.lyric/
But, it is NOT possible with this app https://homey.app/a/nl.bevlogenheid.evohome/
In that case I’ll suggest using external temperature sensors like Aqara
