Advanced flow, alarm_contact, when card and exclusions
Hi!
I have an advanced flow with this when card:
  • In Home zone, when any alarm_contact is running
But I want to exclude some devices, I don’t want to use all devices.
How can I do? I’ve been turning the problem over and over in my mind without finding a solution.
Thanks :slight_smile:
The Home zone, is normally the top level zone that includes all devices.
Some options:
  • Use the zone card of a sub-zone/room that includes only the specific devices you want;
  • If needed, you can create a separate zone with only the devices you want or to exclude a certain set of devices. This does mean that a room might be split up into several rooms;
  • Alternatively, instead of using the zone card, use the trigger cards of the individual devices.
Further: you are checking all alarms right now. Not sure whether that is your intention, but you can also specify specific types of alarms (e.g. battery alarms).
Thanks for your reply. I can’t create sub zones for readibility reasons. (I already have 16 zones!)
I find a way ; I have renamed the only devices I want to exclude with a specific tag, that I check with a logic card “and”.
My “when” card checks only “alarm_contact” :slight_smile:
@Nicolas Can’t you use this setting in the sensor so that it doesn’t count towards zone activity?
Excluding solar activity.
So sorry for my late answer.
No it doesn’t work. With the “when” card “any device vibration”, the excluded device is not excluded of this card.
But with a specific name tag, I can test the name of device and exclude it after the when card :slight_smile:
