How to get label to reflect actual alarm?
Hi!
I’m sorry for the non-english screenshot. But I’d like to have a flow where when the last person leaves the house, if any contact alarm then isn’t disabled, I’ll get a push notification saying WHICH contact alarm is active. Is there no way to fetch that information from the “All alarms” card?
You should def check out this flow
Thanks!
So I guess I’ll have to go with a similar solution to my other thread as well:
I kinda miss a “If this sensor is active in this zone - Then in the same zone enable/disable this device”
But won’t that mean any sensor in that zone? I do not want f.ex. a motion sensor to disable heaters.
A zone gets active when a motion-/contact sensor alarm turns on → IF “Exclude from zone activity” is not enabled that is:
With multiple sensors in a zone, you can choose which one(s) should activate the zone, by enabling the beforementioned ‘Exclude from zone activity’.
This way, you could exclude motion sensors, and include contact sensors.
Thanks! I appreciate it. I haven’t used “zone” for anything before.
