Hej
Ăr det nĂ„gon som vet nĂ€r uppdateringen kommer sĂ„ att man kan köra Advance flow ifrĂ„n appen i telefonen. Ibland kanske man vill köra specifika flöden manuellt.
Kan nÄgon svara pÄ detta.
// Mats
Hej
// Mats
You can run/execute Advanced Flows from the Homey mobile app already. Just make sure you add a START button in your Advanced Flow, and link it to the beginning of the flow (or which ever part of the Flow you want to start from)
For example:
This Advanced Flow would be triggered if the physical button was pressed, or if executed by the round Blue START button (which also allows for starting from the Flows page in the app)
Hej
Jag fÄr det inte att fungera pÄ det sÀttet du förklarar.
Kolla pÄ dessa bilder sÄ kanske du förstÄr vad jag menar ⊠jag kommer ju inte Ät advance flow med telefonen, dessa Àr markerade grÄa och det stÄr tydligen att man ska gÄ in pÄ web appen för att kunna köra flödet.
MÄste sÀkert till en uppdatering innan det funkar.
// Mats
I hope you can translate this into English. Iâm sure you can.
âI canât access advance flow with my phone, these are marked gray and it apparently says that you have to go to the web app to be able to run the flow.â
You can not edit or view Advanced Flows in the mobile app at present (I have seen a number of requests for this functionality in the mobile app on the forum, including my own ha ha).
If an Advanced Flow is greyed out in the Flows list of the mobile app, I only know of two things that can cause that. Either the flow is disabled, in which case it wonât execute other than in the browser editor. Or there is not a START card (the blue play button circle) added within the Advanced Flow, so it canât be manually executed.
Do you have a screenshot of an example Advanced Flow you are unable to manually execute and showing up greyed out?
It wonât work without this part in your Advanced Flow:
Hi again
My flows, whether regular or advanced, work according to time and the movement of the sun. I have tried adding the little blue start button but it doesnât matter, I canât access my advanced flows via the phone app anyway. All advanced flows are grayed out in the phone app. Ok Iâll send you a flow so you can see, I have tried adding the blue start button but regardless of start button or not, the flow is inaccessible on the phone. My thoughts are to create more advanced flows and change the regular flows for the better, but it will have to wait a while until everything works on all different platforms.
//Mats
I donât see the blue Start button in that flow, or how it is linked in to that flow. So that flow would definitely show greyed out.
For example:
Weather - Forecast flow:
Weather - Rain flow:
I hope you can see the difference, and how the Start button has to be linked in to your Advanced Flow for it to work. I hope this makes sense and demonstrates it clearly. Good luck ![]()
