ADEO/Lexman app
I have built an app for the ADEO LDSENK02F smart plug for an app request. Unfortunately, the person who requested the app doesn’t respond to my DM. That’s why I’m publishing it here:
I don’t know if it works, I don’t own the device myself. If anyone owns this device, please let me know if the app works!
Ciao riesci ad inserire il videocitofono
Which mobile app does it use? This one?
Which features do you want in the Homey app? It might be possible to add events, actions and maybe also video snapshots, but live streams will likely not be possible (many camera manufacturers use an encrypted/proprietary P2P protocol for the live streams)
Si utilizza quella app.
Sarebbe bello se puo
aprire la porta
Dire che hanno citofonato
Bonjour,
Je viens d’acheter une box mini.
J’ai réussi de connecter mes prises ADEO de 16 Ampères et celle de 10 Ampères grâce à l’appli Lexman app.
Merci.
I just bought a Homey Mini box.
I successfully connected my 16 Amp ADEO sockets and my 10 Amp ADEO socket using your Lexman app.
Thank you.
Does the energy monitoring work as well?
Bonjour,
Sur la prise concernée est branché mon sèche- linge.
Depuis hier, il n’a pas encore été utilisé.
Dès que je l’aurais utilisé, je pourrai vous donner la réponse concernant le relevé de puissance consommée.
Je vous tiendrais au courant
Cordialement
Bonjour,
Après fonctionnement du sèche -linge, je n’ai pas de remontée de la consommation d’énergie.
si vous avez besoin d’information sur ma config, dite le moi.
Cordialement
After the dryer has run, I don’t see any energy consumption readings.
If you need any information about my system configuration, please let me know.
Regards
Can you create a Diagnostics Report (More→Apps→Lexman→Settings (top right corner)→Create diagnostics report)?
Fait
Code diagnostic
404b78f7-5802-48b8-862b-59fb9316d7ef
