Hi , how to adding shelly devices , witch are connected in a second Shelly WIFI network?
I use a Shelly Pro 1 device , LAN connected & enable this device as Access Point.
Now I added other Shelly devices to this Assess Point
3.In the Shelly APP , I see these added devices
In the Homey App , I only can add the 1 device that is connected by LAN , but can not Adding these devices witch are conneted to te Shelly Access point
Yes you can, but then the two networks shall form one Ethernet network, as you would do with any extra WiFi access point. And for example use the same IP-range. You have to look that up in your manual how to do that.
It will resemble like setting your Shelly in bridge mode, so DNS is switched off.
