Accidentaly removed Homey Bridge
I accidentally removed my Homey Bridge and when I try to set it up again it says that my beta invite code is already in use. So I can’t re-add my Bridge.
Someone know a solution?
I did the same thing. Did you get it resolved ?
Haven’t found a solution yet
This is a user community so no help available on this subject. You’d better contact Athom support directly.
You mean you removed Homey app and your Homey Cloud instance?
(Homey bridge is a physical add-on device, which can be removed and re-added w/o problems, AFAIK.)
When you removed Homey app, just request a new beta code
Have contacted them. No answer yet.
So I thought I could reach out for help here on the forums, in case somebody had this problem before and knew a way to fix it.
Sorry if the community is not meant to be used for getting help on issues like this.
I removed the device from my Homey app, and when trying to add the device again I need to enter my invitation code.When I enter the code, it says that it’s already in use.
Did you request another code? You might need to use an other email address
I just requested one, and got the code the next minute. I’ll PM it to you, ok?
How long does it take for a new code? I did same thing but been waiting for a new code now for awhile
One minute. Did you check the spam folder? Maybe you can borrow someone’s email address and request for a code again.
Well, just check your inbox here :wink:
I’ve requested, but haven’t got anything. Checked my spam filter also.
But luckily I got one from you - thank you very much!!
Anyone find a solution? Have The same problem.
Read the whole topic might help
Post #9 for instance
Got new code but cannot aceess it anymore. Is it bound to ohter code?
Did you get my message @Danbar78
