A request for simple Sonos Roam 2 flows for the bathroom
I want to turn the radio on with a Sonoff button. A single click should turn the radio on, and a double click should turn it off. At the moment, I can only turn it on, but turning it off does not work. Do you have any advice? Right now, it is not connected to a charger. It works only over Wi-Fi and is running on battery, but soon it will be connected to power.
Can you share your (not working) Flow for turning off?
That doesn’t work, you are pausing the speaker and then toggling Play/Pause. Since it’s already paused, this triggers the Play command.
Remove the second card from the pause Flow.
Okay, thanks. I’ll try it and let you know if it works.
It works. I think the issue may also be that it is not connected to a constant power supply. After a while, it probably turns off. Could that be the problem? Or can it go into standby mode?
I have no experience with Sonos, but the device might go into a sleep mode after a while. Does it still work in the Sonos mobile app?
Yes, I also noticed that there is an option in the app to enable a kind of sleep or power-saving mode. So I will wait for the power adapter and keep it connected to a constant power supply so that it does not turn off and can respond immediately. At first, the Sonos app in Homey Pro did not work for me directly, and I had to download the local IP version instead.
