I haven’t tested agains Blue Max devices. Currently Im in development against BlueAir AWS API. Yes, they have two. So I’m reverse engineering their API via their APP on a samsung that I hacked to get all network traffic while doing operations. takes time.
@Jonathan_K you can try the new test version. look up the BlueAir app and att /test to the end of the URL. Connect by clicking the Healthprotect device. If that works, then if I can borrow your unit (credentials) I could check what capabilities it has and build the specific device driver. Let me know.
I have installed the test build and tried connecting with my BlueAir credential. However I have received an error message saying, “The provided credentials are not valid”
Hi Jonathan, I’ve tried by all means to connect to my DustMagnet (which I can access via Blueairs own app so it is available this way). I get errors trying to log in using the Blueairs credentials. Any hint on how to proceed?
When attempting login via Homeys web interface on my computer I recieve a popup saying “Network request failed” and trying via the Homey Android app gives “Timeout after 30000ms”.
I tried to shorten the password to the minimum safety requirements but that didnt help.
It’d be real nice to have access to the sensor data in the HomeyPro-apps…
I’m sad to hear the app has been installed 63 times, but it works for at least a few. We have to see if your credentials are connected to a new set of Amazon sweater clusters. if you DM me we could to some test and I could update the app backend.
I have just brought the Blueair 3250i based on a recent blog on Homey which said it worked with Homey.
I can’t get it connected, the app accepted my password but tells me no new devices have been found.
What am I doing wrong?
Literally just came here to say about this device superb! I notice in flows it mentions about temperature, but I cannot see that in the stats provided? I’m not sure if it has a thermometer, or that its just part of the integration?
Update on my Blue Pure 311i Max integration (two units) using the test version of the app:
Good news — both purifiers were successfully added to Homey Pro (Early 2023). However, the only flow cards currently available are the “When” (trigger) and “And” (condition) cards. There are no “Then” (action) cards available for the 311i Max.
Ideally I’d love to be able to control at minimum:
Fan speed
Auto mode on/off
Night mode on/off
Standby/on
Happy to test any new builds you push, share credentials, or provide any device diagnostics you need to build out the action cards for this model.
In the official BlueAir app for iOS and Android they fetch this data from an external service. There is other apps I homey doing the same fetching external metrics from metrology sites
Also, I clicked you link in the email chain below and this is in a different language. I am here in the USA. Not sure if the test app I have is different.
