[APP][Pro] Ohmigo - Ohm On Wifi
Contribute
If you enjoy what I do, consider supporting me on Ko-fi or Paypal! Every little bit means the world!
ko-fi
paypal-donate
Introduction
Simplify everyday life with smart technology. OHMIGO® offers smart products that help you in the energy transition.
Ohm On WiFi - Control with resistance
OHMIGO® Ohm On WiFi can send resistance as an output signal and can replace your current temperature sensor. It is available in two versions.
In almost all types of control systems there are sensors that detect and control the current temperature.
What if one could easily replace such a temperature sensor with a new type of component that can simulate any temperature and that can be connected to the internet?
Supported flow cards
When
  • Temperature changed
  • Temperature becomes greater/less than Number °C
  • Resistance becomes greater/less than Number Ω
Then
  • Set temperature to Number °C
Use cases
  • Measure temperature remotely and drive a thermostat sensor input with an Ohmonwifi to control your heating.
Useful links
Example flows
FAQ - Frequently Asked Questions
TODO - Features Requested
If you would like to request a feature to this app, please open a feature request at Github.
Known issues
Placeholder
@TobbeG , it is alive.
But at €88 / unit, it is probably the most expensive solution out there!?
It’s worth it, larger volumes at discounted prices, of course.
I haven’t seen any solution that can generate or simulate any temperature sensor from Pt100 which is 100ohms@0’C to commonly used NTC sensors such as NTC22k which has 22kohm@25’C with 0.1’C precision.
Ohmonwifi allows you to control your old analog system from your Homey Home automation.
This app is seeking for a new developer fir continued support.
