2 Nest Thermostat in Google
Hello guys,
I’ve got a question about the Nest Thermostat.
I got Nest connected with Homey but after i synchronize all the devices to Google there are 2 Thermostats.
Is there a way that the Thermostat in Homey does not synchronize with Google?
The other way is to disconnect Nest with Google. Only that is not possible anymore.
Thanks already!
No, unfortunately we can’t select certain devices only to sync
To remove the ‘double’ device coming from Homey, the only option is, to create another home, call it ‘zombie’ or whatever, and then move that device to that home.
Now you only have your Nest thermostat from the Google integration in G Home.
Hi community
I’m fully aware this isn’t a Homey problem. Excuse me for that.
Before two weeks ago:
I have a nest thermostat which is visible in the Google home app. The nest thermostat is also visible in the Homey app.
Now:
The nest thermostat is offline in the google home and therefore not connected in the Homey. The thermostat is connected to the nest app. The temperature can be set via the app connected to wifi and via the cloud. It is also online in my netgear.
Actions I took:
1 reset nest thermostat
2 reset netgear router
3 google home and nest app / thermostat are connected to the same google account and the same wifi network.
4 I am missing the nest app in ‘works with google’ section
Is there someone who is experiencing the same issue? And maybe was able to solve it.
Rogier
