[APP][Pro] Cadabi (formerly Enertek) – tested Zigbee devices that just work
Hi everyone,
This is the official topic for the Cadabi app, previously called Enertek. The app ID hasn’t changed, so your existing devices and Flows keep working after the update – only the name and icon are new.
What it does
Cadabi is the official Homey app for Cadabi’s tested Zigbee LED controllers, remotes and wall panels, with ready-made Flow cards. The same hardware is sold in many versions with different Zigbee IDs, and not all of them pair or behave the same. Every device is tested with the app before it’s added, so pairing, dimming and colour control simply work.
  • LED controller 5-in-1 – single colour, tunable white (CCT), RGB, RGBW and RGB+CCT. Choose your strip type when pairing.
    Compatible with SkyDance WZ5 – Zigbee: `TS0505B` / `_TZB210_3zfp8mki`
Coming next
  • LED controller for single colour / CCT with push-button input (SkyDance WZ1)
  • RF remotes and battery-powered wall panels
Download
https://homey.app/a/no.enertek.app/
Bugs and device requests
Please post them here, with your Homey model, Homey version and a diagnostic report ID (app settings → Send diagnostic report).
Which remotes or panels would you like supported first? Let me know below.
Support the project
The app is free. If it makes your home a little smarter, you can buy me a coffee :hot_beverage:
https://buymeacoffee.com/cadabi
Thanks for using Cadabi!
Mateusz – certified Homey installer & KNX Partner
I see you have an official app, did you know that you can add Homey Cloud/Homey Bridge support by replacing
"platforms": [
    "local"
with
"platforms": [
    "local",
    "cloud"
in your app.json and your driver.compose.json for all drivers?
Thanks for the tip! I didn’t know that was possible for official apps.
Since the app only has Zigbee drivers, it should work on Homey Bridge too.
Cloud support will be in the next update, together with support for more controllers.
If anyone on Homey Cloud tries it, please let me know how it goes.
