I have currently released a test version, and I will try to provide support as much as I can based on the feedback I receive. As I am both a student and working, I will try to update it when I have time.
HomeKit Device Bridge for Homey
Bring supported devices from your local Homey system into Apple Home with native HomeKit controls, fast local synchronization, and a single configurable bridge.
The app runs locally on supported Homey systems. Homey Cloud and Homey Bridge are not supported because HomeKit bridging requires local network access.
Supported Accessory Types
HomeKit Device Bridge automatically detects your Homey devices and exposes compatible capabilities using the most suitable native HomeKit accessory type:
- Lights: On/off, brightness, color, color temperature, and Apple Adaptive Lighting where supported.
- Switches & Outlets: Reliable power control and state synchronization.
- Climate: Air conditioners, heat pumps, thermostats, fans, air purifiers, and humidifiers with supported controls and sensors.
- Window Coverings: Blinds and curtains with position and horizontal tilt controls where available.
- Security: Locks, garage doors, doorbells, smoke alarms, motion sensors, contact sensors, leak sensors, and tamper status.
- Sensors: Temperature, humidity, air quality, battery, and other supported measurements.
- Remotes & Buttons: HomeKit button events for supported Homey remotes and controllers.
- Smart TVs: Native HomeKit television accessories with input switching and Apple Remote support where available.
Native Features
- Automatic Discovery: Compatible Homey devices are detected and categorized automatically.
- Selective Bridging: Choose exactly which devices you want to expose from the app settings.
- Offline Awareness: Devices that are unavailable in Homey are reported as not responding in Apple Home.
- Stable Pairing: HomeKit IDs remain stable across normal app restarts to preserve rooms and automations.
- Flow Starter Devices: Add one or more Flow Starter devices in Homey, expose them to Apple Home, and use each switch to trigger a Homey Flow.
- Local & Fast: Device communication and synchronization happen locally on your Homey system.
Setup Instructions
- Install the HomeKit Device Bridge app on your supported local Homey system.
- Open App Settings and select the devices you want to expose.
- Pair the main bridge using the setup code shown in the orange bridge card.
- Pair TV accessories separately when you want native Apple Remote support.
- Use the reset options only when you need to regenerate a HomeKit accessory identity.
Support & Donation
If you find this app useful and want to support its development, you can buy me a coffee!
Donate via PayPal: PayPal.Me
Developed by Ugur BENEK (ugrbnk@me.com)
Camera & HomeKit Secure Video Testing — Volunteers Welcome
Hi everyone,
I’m preparing a test release of HomeKit Device Bridge with camera support and would appreciate your help testing it across different Homey setups.
What’s included
Live video from compatible cameras added through the UniFi Protect Homey app.
Camera motion sensors in Apple Home.
HomeKit Secure Video (HKSV) recording for compatible streams.
Recorded audio through compatible AAC-LC passthrough, without continuous audio/video transcoding.
Separate ARM64 and x64 media packages.
Cameras are disabled by default. You can individually enable camera export, motion sensors and HKSV in the Cameras section of the bridge settings. HKSV compatibility depends on the camera stream and your Apple Home recording setup.
Live video, remote access, motion and HKSV have worked in my Homey Pro setup. However, real-world Self-Hosted Server testing is still needed, particularly on Intel/AMD x64 systems and Mac mini installations.
Please help test
Local and remote live viewing.
Multiple motion recordings over time, including recorded audio.
Camera switching and simultaneous viewing while HKSV is enabled.
Recovery after a camera disconnects or the bridge app restarts.
CPU and memory usage over 24–48 hours, including whether usage settles after viewing stops.
Whether existing non-camera devices and Flows continue working normally.
When reporting results, please include
Bridge app version and Homey model/SHS setup.
Camera model and Homey integration used.
Apple device/OS and active home hub.
What worked, what failed, and how to reproduce the issue.
The Download camera report option in the Cameras section provides an anonymized report. Please do not post passwords, HomeKit setup codes, full camera URLs or unsanitized diagnostic logs publicly.
This is a test release, so please keep a backup and avoid relying on it as your only recording system. Update your existing installation without uninstalling or resetting the bridge.
**Test version: HomeKit Device Bridge | Homey
Thanks to everyone willing to help. Feedback from different setups will help us identify compatibility issues before the wider release.
