After 15 years of Home Automation with Fibaro, I have (finally) switched to Homey Pro.
My main Energy Meter is an Eastron SDM630-Modbus for which I could not find a Homey app, so I built one. Next to an app to retrieve all data an Modbus TCP gateway is required. You can buy them at many places or built one like I did (see link to Github project).
It works perfectly with the Energy dashboard of Homey and now I can automate my EV charger to charge when my solar panels start to export energy to the grid.
Nice work, Rob I will test these for u. in my setup, ok they will make doble intergrate the data, but for the test ik can be done.
But you say you never find a app to use the eastron’s, bu I use all ready for years the homewizard app for connect to my Eastron’s (5 in totals) 2 3fase’s and 3 1fase meter’s
I do not want to go through an API, I could do a similar thing with the Growatt app (great app but connects to the Growatt cloud).
My app reads the Modbus registers directly (not going outside my network) which is fast and save.
Additionally I added extra functionality like “Power imported per day”, “Power Exported per day” and “Net Power usage” (Total exported - Total imported).
Wow! This is exactly what I was looking for. Nice work Rob!
I have a couple of SDM72D-M and SDM120M energy meters in my setup. If you would be able to add these as well that would be amazing.
I’m happy to help test these devices.
Yes, would be great to add those first, I will sent you a message when the app is ready for testing.
I do need your feedback as different meters use different registers (the core app supporting this), I can find the info but testing will confirm the correct implementation.
I have this meter to trigger my heatpump on solar panel energy over capacity.. I want to track kWh usage of my heatpump… And curious what data you provide… But… Now the meter is physically linked to my heatpump… What can I do to connect to homey
Hi @Wout_van_den_Dool you can extend your Modbus with a cable and attach a Modbus to TCP gateway.
I build one myself (<10 Euro) ESP32 gateway, but you can also buy a Modbus to TCP gateway.
Then with my Eastron app you can connect to the gateway and receive all available data points.
All so with the API on it works over your own network, no internet or cloud needed.
With these Modbus meters you need again a secondary cabling with a gateway, for on one place handy, but on several places in the house (ceiling, swichboard, barn) you need all so more Modbus to tcp gateways.
I’m hoping someone here can help me with my setup.
I’m trying to get an Eastron SDM630 Modbus V2 working together with a USR-DR134 Modbus RTU to TCP gateway. Unfortunately I can’t get the communication working correctly between the SDM630 and the USR-DR134.
The TCP connection itself is working fine. Homey can connect to the USR-DR134 without any problems, so I’m quite sure the issue is not on the Homey or network side. My feeling is that something is going wrong in the Modbus RTU to Modbus TCP translation, or in the way the gateway communicates with the SDM630.
On both the SDM630 and the USR-DR134 the Modbus settings are the same: baud rate, stop bits, and parity are configured identically. I can see the RX on the TCP gateway incrementing, but the TX never seems to respond. As far as I know, the SDM630 firmware is still original.
Thanks a lot for your time and suggestion. I changed the parity to “None” and set the polling to 1000 ms, but unfortunately it didn’t solve the issue. I also tried swapping the A and B wires on the SDM630, but still no luck.
One additional thing: when I set the work mode to Light Edge in the USR gateway, I do see activity on both RX and TX, but no data is received in Homey.
Do you have any idea what else could be causing this? When my SDM630 starts, it shows Soft 32 01.03 on the display, which seems to me the original firmware.
I have no experience with the USR-DR134, is the slave ID (client) correct?
Default is 1 for the SDM630 (I changed that to 2 as my Growatt inverter is also 1 and they are on the same bus).
I am still in doubt because I am not sure if this device is the only one on that phase… Because if my other electric devices also go via this phase it is not worth measuring this… I want to know my heatpump energy usage only, ultimately which part derives from solar panels and which part from the net… But probably not possible the latter…
So I bought this device and downloaded your Eastrom app:
But stuck here and waiting for an answer on this ticket: Subject: RS232/485 to Ethernet Converter – Unable to Discover Device on Network (Mac / Deco M9)
The root cause you are not seeing the Waveshare device is because you have a different IP range: 192.168.68.x.
You need to bring the device in your range, to do so:
connect your Mac to your network and adjust the internet settings (from DHCP to manual) and set an IP address in the same range as the device (not exact same address), like 192.168.11.100 (or 192.168.0.100 if “0” is the default range)
Now you can use your IP scanner (I use LanScan on my Mac) to find the address of the device.
Log in the device and change the IP Address (to a free address) so it will be in your range (192.168.68.xxx)
Set your Mac back to DHCP and scan your network again, now you should find the device on the address your set it to.
