[APP][Pro] Wallbox Charger - Smart EV charging technology made simple
Split from this Topic Wallbox Pulsar plus charger lock/unlock pause/resume
I’ve just implemented it within the app and I’ve published it.
Wallbox Charger App for Homey | Homey
It contains at least the following:
  • triggers when car connected/disconnected, charging started/resumed, etc
  • actions lock/unlock, pause, resume
For those interested this is the app:
This is just the initial version, so some bugs may be present, please fill in a github issue page if you found any.
Been away a bit and there’s now an app! Nice!
Tried it, but it won’t let me install a wall box when adding a device. I just see the icon with a red :red_exclamation_mark: in a triangle
I’ve just verified my own installation and unfortunately I cannot reproduce the issue. Could you verify the same things as mentioned here:
I need some additional information to check what the specific issue is.
That is indeed what i also encounter.
Since the app has no configuration, there’s not much else i can test. Running homey Pro 2023. Also have the wall box homey script, that runs fine.
Okay, it should now be fixed, for further info and a working test version see the GH page.
Excellent app. Works flawlessly. Thank you very much for your efforts to make this available!
Yep! Thanks!
great job @rkokkelk
do you want me to do the French translation?
Yeah that would be great. I’ve just did the groundwork for it based on the NL translations. So if possible could you make a pull request on Github and then adding the appropriate “fr” translations in the app.json, driver and device compose json files and README.txt, the same way it’s document for the NL language.
If you’re unable to do a pull request feel free to share your translations with me personally and then I’ll add them to the app.
I have already done translations for other applications, I’ll look at it in the next few days
Good morning @rkokkelk ,
the translations are pooled at github, I think everything is done.
Hi Moreau, yeah it helped out a lot, so thank you for your effort. If you would like to be mentioned as a translator please ping me with a PM.
cool, no thanks I’m doing this to help and nothing else.
tell me when you update that I check if I haven’t made any mistakes
Hi, is it possible to add more Then flow cards - like changing AMPs?
Is there a way to support developer with “coffee”? :slight_smile:
@Sen-Sai would it be possible to add a tag for the current authenticated user of the charger? I am using this to divide charging costs between different users, so i would like to know the current user of the charger. Thanks :slight_smile:
Hi, I’m currently working on that, because it is a much requested feature. Hopefully I can release it this week.
So far no coffee support possibilities, but I’ve gotten this question multiple times so maybe I’ll add a button soon. But the thought is already highly appreciated.
New Homey arrived, this app was the first that I did install :wink:
First device went well, but when I chose to install a second device to make a second instance with different credentials it tells me “no new device found”.
So, our usecase is to use a Wallbox instance dependent on the car to be charged (business/private).
Hope you can help me out.
It was not possible to use the app. I removed and installed again, now it is not possible to log in see screenshot.
Tried to log in on mywallbox, this was no problem.
Hi I use this for my Commander 2 Wallbox and it worked perfect for some time
Now I get Error 404 message when I try to unlock it. I already reinstalled it and switched to test version. Everything besides that seems to work
