[APP][Pro] Schedule Message
Schedule Message - Easily schedule messages to be sent at any time from your Homey.
Useful links
Features:
  • Schedule messages to be sent at a specific date and time.
  • Supports categories for organizing or filtering scheduled messages.
  • Compatible with other Homey apps that can process messages (e.g. Telegram, WhatsApp, Signal, Slack).
  • Optionally specify a recipient for each message.
  • Supports raw data input for advanced integrations.
Usage
  1. Install the Schedule Message app on your Homey.
  2. Create a flow using the “Schedule Message” or “Schedule Event” action card.
  3. Enter the message, date, time, and optionally a recipient and category.
  4. The app will trigger the scheduled message at the specified time, allowing other apps to process or forward it.
Advanced:
  • Use the “Schedule Message (raw)” action card to schedule messages using a single text string in the format:
    date|time|recipient|message
    Example: 04-12-2025|12:00|+31612341234|Hello World
  • You can also use a prefix to strip from the raw data if needed.
Supported Languages:
  • :uk: English
  • :netherlands: Dutch
  • :denmark: Danish
  • :de: German
  • :es: Spanish
  • :it: Italian
  • :norway: Norwegian
  • :sweden: Swedish
  • :poland: Polish
  • :ru: Russian
  • :kr: Korean
Contributions
If you appreciate this app, contribute to future development by making a paypal contribution
or buy me a coffee on Ko-Fi or Bunq.me
image ko-fiimage
:laptop: Apps made by @martijnpoppen
See for more apps link below :backhand_index_pointing_down:t2: or just open the pull down.
Examples
Whatsapp:
What it looks like in Whatsapp:
Placeholder 2
Placeholder 3
Nice, finally a small upgrade to my very, very basic flow I made for reminder messages.
Just a curiousity, will there be a settings page to manage the messages?
example you made a mistake so would be nice to remove or edit said schedulded message.
Or add 1 manually over there without having to install another app or create a special flow for it.
small bug in v1.0.2: 1 of the action flow cards isn’t registered (properly): set_scheduled_event
@Caseda yes that’s still something I need to add :slight_smile:
Oh will check the bug thanks!
New app update (:orange_square: TEST: 1.1.0):
Changelog:
NEW:
1: NEW: add settings page
2: NEW: add delete flowcard
FIXES:
1:FIX: Flowcard not registered
More - apps - Schedule Message - settings wheel right top - send diagnostic report (put your email in the input field to make it easier)
You can install the test version by clicking the link above and press install
Don’t want to be part of this test version? Install the live version → Schedule Message | Homey
@Caseda see above :slight_smile:
So d*mn fast as always.
Edit: flow card is indeed fixed.
Though when adding a message via the settings page recipient and category are swapped on the overview page, and the recipient is empty, unlike the flow card, where recipient then is Unknown recipient
@Caseda will check
New app update (:green_square: LIVE: 1.1.2):
Changelog:
NEW:
FIXES:
2: FIX: incorrect input from settings page
@Caseda Fixed :slight_smile:
Hi @marijnpoppen, this app is really cool, but I can’t get the “And” card to work. I simply can’t figure it out; I’ve been testing and messing around for over half an hour. Everything else seems to work. When I run tests without this And card, it works just fine. Do you have a golden tip for me? Even when I run the test with the message “2025” and the “And” card is “text contains 2025,” it doesn’t work.
Edit: when I try it now on WA, it does work :smiley:.
@TheBigFella thanks
However this is a English topic
Please edit and translate your pos
@TheBigFella for the AND card to work (which is a WhatsApp app question, so better in different topic) you have to send a message
Test mode doesn’t work for WhatsApp
Tried with 2025 added to the text message as well?
Ah right, that’s it then. I got it to work now, by testing it trough Whatsapp only.
@Peter_Kawa - The problem was that testing doesn’t work for WhatsApp.
