Enphase - Harness the sun to make, use, save, and sell your own power.
Central topic for questions/discussing the Enphase App. You can use this topic to ask questions and share your experiences with the Enphase devices.
This thread is not actively monitored by Enphase or Drenso. For official support use the e-mail link in the AppStore Support Contact ».
Unstable results
Enphase updates the Envoy firmware automatically, and these firmware version are not always stable causing incorrect readouts. That is not always solvable by us, but make sure to let us know when issues arise!
Hopefully the app will be expanded.
Just current power and total revenue is not enough yet.
My Solar panels app still works and there you also have the current power solar panels, current own consumption, power grid purchase and total generation.
Before, the total consumption (kWh) was also there. (solar panel consumption + net offtake).
I know it is abandoned.
I have tried this app to. But as long the “old” app is working i don’t want to use both of them.
With the zonnepanelen app on 2 Homey’s, on one of them the Enpase was every couple of hours unavailabel.
But i wil follow this tread to see what will happen.
I have just installed this new / revamped Enphase app, and it gets data parsed over from my Enphase PV system.
I already have in use a virtual device for my Enphase PV system that uses the data from the integrated P1 meter PV build into my Sessy homebattery, and that information is also visible and tracked in Energy. Also via Power by the Hour I am able to track cumulative kWh and €-value generated.
By default, the Enphase app has the setting “Exclude from Energy” set to No. Does this mean that I can set my Enphase virtual device setting for “Exclude from Energy” to Yes and the Enphase app is going to take over / feed the statistics in the Energy tab?
Frank, how did you connect the “new and official” enphase Homey app to your inverters… I keep getting the message that my credentials are not correct.
Thanks in advance
Jelle
I only needed to use my Enphase credentials (so the one I also use to login to the Enlighten webpage of Enphase), and then it worked for me.
You could try first to login at Enphase to check the username and password you use is correct: if so, then it should work with the Enphase app also on Homey. Crossing my fingers for you.
In case problem continues, then try to remove the Enphase app from Homey and after that reinstall it and try again.
Inlog credentials for Enphase app and Enlighten website both work (are the same) but these still don’t work in The Homey official Enphase app…tried to uninstall and install.. still these same message..
yes, V0.3.0. Tried everything …un-install even switching phone off and on. keeps saying credentials are wrong. Inlog on enlighten app on phone has no problem with the same inlog credentials
If (one of) the credentials start with a letter, you’d check if the first letter doesn’t get auto-capitalised somehow.
Hidden white spaces can ruin things as well.
Still not able to log in with the enphase credentials. Because it’s a official app i’v asked the developer for advice but no response jet.
I’m I the only one with this problem?
Every one or two days, my Enphase device gives an “Internal Server Error”. I can remedy it by restarting the app. Looks like a bug. Error/bug reported: 0f62e326-7e97-4f23-bba4-4280c1fdf183
