[App][Pro] Elgato Lights - Illuminate on Command
Elgato lights are known for being the perfect solution for content creators, providing high-quality illumination that enhances every stream, recording, or production. With this Homey app, you can now effortlessly manage your Elgato lights alongside all your other smart home devices, ensuring a smooth and unified control experience. Adjust brightness, color temperature, and power at the touch of a button, or include them in your custom scenes and automations to create a professional-grade environment that’s ready whenever inspiration strikes.
By integrating your Elgato lights into Homey, content creation becomes even simpler. Imagine being able to instantly set up your lighting for a shoot with a voice command or have the ideal mood lighting automatically activated when you start your stream—all in sync with the rest of your smart home. This app lets you focus more on creating great content and less on the technical details, making your workflow more efficient and enjoyable. Bring your lighting under control with Elgato Lights for Homey and create without limits.
Note: This app is not officially endorsed by Elgato.
Thank you, works great! Any chance you could support the Key Light Mini?
I currently don’t have a Key Light mini in my possession, but I’m trying to see if I can loan some devices from Elgato.
But it should be possible to support it. In the meantime I’ll see if I can order one this weekend :+1:
I’ve noticed a few crashes of the app, so I pushed a test version that should hopefully address this.
Version 1.0.6
  • Fix potential crash
@TomAnthony
I’ve pushed a new test version with support for the Key Light Mini!
Version 1.1.0
  • Added Key Light Mini and driver icons
Thanks, works great with my Key Lights !
Any hope for supporting Ring Light ?
Yeah, should be possible.
Let me see if I can acquire one for this weekend!
I’ve been trying to get my hands on an Elgato Ring Light, but it seems like everywhere I look, they’ve jacked up the price to over 200% of the original MSRP.
So, I thought maybe you could help me out with some info @DJP. The Ring Light has pretty much the same features as the other Key Lights, so I should be able to set it up without even having one physically. The main thing I need to know is how it advertises itself on the network.
Could you please get me all the mDNS-SD information related to the Ring Light? You can use Discovery on macOS or Bonjour Browser on Windows to get this info.
Either a reply in this topic or a direct message is totally fine!
elgato-ring-light-2289.local.
192.168.0.X:9123
mf=Elgato
dt=201
id=3C:6A:X:X:X:X
md=Elgato Ring Light 20LAC9901
pv=1.0
Uploaded a test version with experimental support for the Ring light @DJP!
They device icon is still an obvious placeholder :wink:
Version 1.2.0
  • Added Ring Light support
10/10, everything works, toggle / dimming / temperature !
Thanks a lot :slight_smile:
One less device on home assistant :stuck_out_tongue:
I am trying to setup this app - for some reason it only wants to detect one of my key lights. They are both available in control center and work fine. The only difference is the one not working correctly is the new MK.2 variant so I am not sure if there something “new and improved” there. Anyone see anything similar?
Hi @Sean_Larsen
I have a feeling that the mk.2 key lights present themselves differently on the network. Could you get me the mDNS-SD information of the Key Light that isn’t working? See my message to DJP above, on how to achieve this information.
With that information I should be able to update the driver and make it recognise the newer lights.
I’ve uploaded a new test version, no updated MK.2 support yet.
Version 1.3.0
  • Added support for the Key Light Neo
Here you go - it was interesting this second light didn’t show up until I actually powered it on from Control Center yet the other one did.
Funny enough when I tried to add a key light again - it appeared. So not sure if there is some new default behavior going on here or not. So I don’t know if there is anything to be done other than “power cycle your lights in control center before trying to add”
Type: _elg._tcp.
Name: Elgato Key Light MK 2 60FB
Key: dt
Value: 205
Key: mf
Value: Elgato
Key: pv
Value: 1.0
Key: md
Value: Elgato Key Light MK.2 20GAK9902
Key: id
Value: 3C:6A:9D:26:6E:8C
Thanks for giving it another try @Sean_Larsen and looking up the information for me.
The current implementation should recognize the MK.2 using the default Key Light driver, so I don’t need to update the discovery algorithm. That makes sense, considering it worked when you tried again.
I’ll probably just add a small notice about the power cycle on the first pairing screen, just to be safe. I’m not sure if there’s anything I can do about it not being discovered on the first try.
Appreciate the quick reply. Just very strange but glad it is working. I am tempted to chalk it up to the WiFi on these lamps not being the best. They will sometimes just stop communicating. Thanks again !
Hi all, I just got a homey and I’m trying to connect my key lights air, however, when searching for devices it times out with the following message: “Timeout after 10000ms”. Any ideas on what it could be? I can control the keylights well from control center, and I also have homebrew installed, and can find and see the lights.
Is the app still being maintained?
Thanks!
The app is still maintained, but currently there isn’t much work to do for the app as it’s fairly feature complete.
Have you tried power cycling the light? The WiFi on the Elgato lights are known to be finicky.
Yes, I know they are not the best product. I just tried restarting everything, and now I was able to connect the lights! thanks!. Quick question, do you have the source code for the app on github or the likes?
Thanks for the quick response
