[APP][Pro] Trashcan Reminder 2.0
Trashcan Reminder 2.0 App for Homey | Homey
Homey will remind you to put the trash out! You can do this by providing a postal code, house number (currently NL/BE only), by entering a pattern per trash type, or by defining custom dates. More information about the app and how some example flows can be found here: Trashcan Reminder 2.0 | com.trashchecker
Supported Features
  • Lots of trash collection days are automatically recognized
  • The first trash cleaning service is automatically recognized
  • Manually enter data for trash types if you live in an area where automatic detection is not working
  • Build trash reminders completely to your style with the help of the flow cards and available global tags!
  • Show the trash collection dates on your Homey Dashboard
Issues can be reported here: Issues · robertraaijmakers/com.trashchecker · GitHub
If you want some examples or tips and tricks configuring the app. Check out these links:
Note: For new people checking out this thread before installing the app. Don’t bother about the first few posts from way back when. The app is currently working fine and is maintained as actively as possible and contains a lot of features requested :slight_smile: If you encounter any issues, please report them on GitHub via the link above (you can report them in Dutch or English).
I am a happy user of the trashcan reminder app but the last weeks it doesnt work anymore…
Am I the only one with this problem?
I have restart the app en restart homey.
In settings I have data in the debug part:
But when I test the flow it shows the following sign:
Any suggestions on what to do next?
I have the same issue.
Do you use Afvalwijzer?
There is a bug report at the moment: Afvalwijzer does not work · Issue #45 · robertraaijmakers/com.trashchecker · GitHub
But nobody to fix it.
You get the exclamation if the condition is not met, if there’s no garbage collected today. If you inverse the cards, I expect them to give green checkmarks.
Ah, i didn’t see that one… yes i use Afvalwijzer.
I dont think i can help with fixing a bug so ik will wait untill someone has time tot fix it.
Thanks, but the problem is that there was collection of paper that day…
but i will wait for someone to fix it as stated at github.
My city is supported for all the trash except old paper.
Can I add only the days that the old paper will be collected
and that Trhashcan reminder will also collect the data from “My Afvalwijzer”?.
Same problem here, doesnt work anymore
It didn’t work for me either. Untill it works again I made 3 flows to remind me. Hereby one example
Hoi homey’s
Is er reeds feedback van de app mogelijk voor België namelijk Kwaadmechelen?
Reeds bedankt guys
Same issue here, the app always returns that nothing is collected today.
I’m using the DeAfvalApp, can see the list with all collection dates for the entire year.
So the data seems fine, it’s just the data parsing that goes wrong.
hi!
I translated the app to the Swedish language and made a pull request about it on github. :slight_smile:
/Z
Same issue with ROVA.
Since a few months, the app does not give me any reminders anymore.
I have linked with RD4 and the app indicates I have a valid address.
In the settings info inside the app I can see pickup dates for various kinds of trash, for example today and tomorrow.
However the flow cards don’t allow me to show any sensible reminders.
As an example, I trigger every day, filter on ‘trash to collect Tomorrow / Any type’ and then post a notification. This does not delivery any results anymore.
When I chat with Homey, the device indicates the next trash is collected in 366 days , where, according to the data in the setup page of the App, today and tomorrow (e.g. 17.9.2020 and 18.9.2020) GFT and PMD is collected.
Could there be a bug or is it me? Seems like a parsing issue with the ‘year’ value.
Thanks…
I tested the app by manually adding tomorrow’s date.
When the date is added manually, the date format is YYYY-MM-DD but my automatic RD4 delivered data is DD-MM-YYYY format.
When tomorrow’s date is recorded in the debug info as “2020-09-22” then the App works.
When tomorrow’s date is recorded in the debug info as “22-09-2020” then the App does not work.
I suspect the date format is the cause of the issue.
I have posted a bug report here: Verkeerd verwerken van API data voor RD4 Afvalwijzer · Issue #100 · robertraaijmakers/com.trashchecker · GitHub
Hope it will get fixed by someone
My setup has been fixed. Thank you very much!
Hi, will the trashcan reminder app be compatible with Homey v5?
Hi @willumpie
This app works in Homey V5.
Hio there,
nice app!
any chance to implement Omrin as a trash disposal company?
They handle the garbage in the north of the netherlands.
thanks
